Sailorik
Jeanneau Model: 43DS
Yacht Name: Shibumi
Home Port: Haven Harbour
Post by Sailorik on Jun 20, 2022 16:55:01 GMT
I have noticed that the exhaust flange on my 43DS is leaking a small amount water of water into the stern cavity. I'm not sure how to get into the cavity to take off the nuts that the flange is bolted on with. Has anyone else had this problem or if anyone can offer some insight to fix, I would appreciate it
Post by andreshs1 on Jun 28, 2022 15:49:52 GMT
Hi there
Perhaps a photo or drawing would help to ensure I understand your issue. Anyway, 'if' you are referring to the exhaust to hull fitting, I had a similar issue and had to remove the gas locker in order to access it. Now, to remove the gas locker you either install an inspection hatch at the bottom of the passage to the swimming platform; or you need to remove the aft (garage) locker, so you can disconnect the drain hose from the transom...
I had to do the job several times and eventually I fitted an inspection hatch, now I can just disconnect the drain hose from the locker directly within minutes
wheelsucker
Jeanneau Model: 2002 Sun Odyssey 43DS
Home Port: Seattle
Post by wheelsucker on Jul 28, 2022 15:55:34 GMT
Hi Andresh,
I'm going to tackle pulling the gas locker later this summer - any chance you can post a picture of your inspection hatch installation?
Thanks.
Sailorik
Yacht Name: Shibumi
Post by Sailorik on Aug 20, 2022 11:27:06 GMT
Thanks for the information. How did you remove the caulk so that you could pull out that locker?
Post by andreshs1 on Sept 14, 2022 16:17:03 GMT
Hi Andresh,
Thanks.
Apologies for the delay, I'll take one this coming weekend Regards
Post by andreshs1 on Oct 29, 2022 13:01:14 GMT
Hi wheelsuckerapologies for the delay, sadly sometimes unexpected shxt comes ones way I dont know why but I am not able to post photos anymore (I thought this was fixed...) but this link will work 1drv.ms/u/s!AoZeFtYsW1FthbJm7ldtyAG4QwbBiw?e=cg2vwy Regards Andres
wheelsucker
Home Port: Seattle
Post by wheelsucker on Oct 29, 2022 20:31:51 GMT
Thanks Andresh! Very helpful.
Post by tsenator on Feb 7, 2023 17:43:12 GMT
Hi wheelsucker apologies for the delay, sadly sometimes unexpected shxt comes ones way I dont know why but I am not able to post photos anymore (I thought this was fixed...) but this link will work 1drv.ms/u/s!AoZeFtYsW1FthbJm7ldtyAG4QwbBiw?e=cg2vwy Regards Andres Andres, I saw the pics you had of a washing machine on your 43DS , very cool ! How do you like it ? Looks like a tight fit . Was it hard to reroute the sink drains under the sink ? Tom
Post by andreshs1 on Feb 8, 2023 1:04:07 GMT
Hi Tom As part of the re-routing of the drain hoses, I added a sump box next to the main bilge, this collects the water from the sink, the washing machine and I will add the hoses for the forward shower drain and sink. The sump box has a bilge pump inside with sensor, and drains via a thru hull about the water line. Thus I have removed 2 underwater thruhulls. The project was very straight forward, the only advice is to add the steel plate on the floor to ensure that it will have additional support, and get someone to help you move the washing machine…I did it alone and it was a pain in the rear end… The wife is rather happy with the addition though, and so far has been working great Cheers
