Post by patricmo on Feb 10, 2022 19:43:24 GMT
I'm being quoted $2000 just for the part, not the labor. Does this sound reasonable?
Thank you.
Post by Charlie-Bravo on Feb 10, 2022 21:30:29 GMT
Do you have a Yanmar part number for the item you are being quoted for? It will help
Post by snwl on Feb 14, 2022 9:35:11 GMT
Post by allegria on Feb 16, 2022 4:40:42 GMT
Hi Patricmo,
The price seems way too high... I paid around AUD350 for a Yanmar one a couple of years ago... Part only... It is really easy to replace also... no need for labour on top!
Cheers, Allegria
Post by sitara on Feb 16, 2022 20:59:42 GMT
Exhaust mixing elbow, or full exhaust manifold?
Post by no3l on Apr 18, 2022 23:22:54 GMT
Hi
Seems far too high. The exhaust elbow is relatively easy to replace, don’t forget to order a new gasket There are several sources, exhaustelbow.com do a stainless version.
I’ll post an EU source as soon as I can check where I sourced a replacement a while ago.
Incidentally the original can be welded and kept as a spare.
Noel .
Post by no3l on Apr 20, 2022 16:59:26 GMT
I used this company, no issues. www.parts4engines.com/Unit 9, Riverside Park Sheaf Gardens Sheffield S2 4BB, UK Tel. +44 (0)114 2728626 Regards Noel
GrahamT
Jeanneau Model: SO 49
Yacht Name: Makani
Home Port: Airlie Beach
Post by GrahamT on Apr 22, 2022 6:45:48 GMT
The Yanmar part for a 4JH3-HTE was AUD900 in 2018 so less than USD700. $2000 is way over the top.
GrahamT
Yacht Name: Makani
Post by GrahamT on Apr 22, 2022 6:50:22 GMT
Should have said that was for the "riser" / "elbow".
fma
Jeanneau Model: SO45
Home Port: Miami
Post by fma on Apr 22, 2022 14:47:07 GMT
If this is the entire heat exchanger assembly then $2K sounds about right. I recently paid nearly $4K for a new heat exchanger on a 4JH4-TE from Yanmar (who's dealers are like an organized crime family in US)
Post by no3l on May 6, 2022 21:07:32 GMT
