Post by nettuno on Sept 14, 2021 19:36:09 GMT
Hi, I have a Yanmar 4JH3E with the simple control panel (only tachometer, alarms and then a gauge with engine hours and another with fuel level) and I'd like to connect engine data to a Raymarine multidisplay I have available to read NMEA Data like: • Engine Hours • Engine RPM • Oil Pressure • Oil Temperature • Coolant Pressure • Coolant Temperature • Percent engine load • Battery voltage and current • Alternator potential and current • Total Fuel vol • Total Fuel % • Fuel rate With those data and my Multifunction Display then I'll be able to setup: • Est. Fuel Remaining • Fuel Used (Trip) • Distance To Empty • Time to Empty • Engine and transmission warnings and alarms I'm thinking to add a Engine Gateway YDEG-04 from Yacht Devices: yachtdevicesus.com/products/engine-gateway-ydeg-04 with the Yanmar adapter cable: yachtdevicesus.com/products/adapter-cables-for-ydeg-04-engine-gatewaysAnybody knows if the Engine transmit all those data by default? I should add additional Engine sensors to allow the engine to transmit all this data?
Post by rxc on Sept 15, 2021 17:34:46 GMT
I think you are very ambitious here. Your list of the data you want includes a few items like fuel flow, that are very difficult to measure for a diesel engine, because the fuel is recirculated, and you have to measure both fuel TO the engine, as well as fuel BACK to the tank. You also may not have enough existing locations for all the sensors - oil temperature and coolant pressure come to mind as the first problems. In any case, you will have to add a LOT sensors, and then figure out how to convert their output to a common format that can be digitized. I am not sure how you will measure engine load - I guess you could just use throttle position or add a sensor to the fuel rack position. The alternator and battery measurements will each require a shunt.
I would love to have this info, but am too old to take it on as a project. I bet you could find a lot of people who have done at least a subset, and build off of their experience.
Good luck and let us know how it goes.
One last thought. How old is your engine and does it already have the sensors for this project? The website for the connector says it is for Yanmar 4JH engines, but I know that I don't have any connectors on my 4JH3-TE that could provide the necessary info.
zigzag49ds
Jeanneau Model: 2005 Sun Odyssey 49DS
Yacht Name: Zig Zag
Home Port: Tacoma, Wa
Country: Usa
Post by zigzag49ds on Sept 23, 2021 23:57:42 GMT
Looks awesome to me, I have the Axion display, and this is just what i'm looking for. Go for it and let me know how it works!!
Jeff
Post by so40gtb on Oct 12, 2021 0:44:25 GMT
This seems like a very ambitious undertaking. Voyageur has a Yanmar 4JH3E engine, but I don't believe that it uses a data bus to communicate with the control panel, but will check that. The manual for the interface device makes no mention of the Yanmar engine. And the interface adapter cable appears to be configured to tie into an existing data bus. So this may be a bigger effort than expected.
petros42
Jeanneau Model: SO 419
Yacht Name: Pole Dancer
Home Port: Gabriola
Country: Canada
Post by petros42 on Oct 12, 2021 0:59:17 GMT
I'm not sure if the 4JH3E has the same CANBUS interface as the 4JH45, but this article: jeanneau.proboards.com/thread/6257/yanmar-4jh45-engine-interface-raymarine discusses a solution. I have not (yet) implemented the CANBUS interface, but it is on my TODO list. From CANBUS, I'll go to my Raspberry PI which is able to interface to the Raymarine via SignalK (software) and YachtDevices gateway (YDWG-02). This is more complicated using the YD Yanmar interface. I look forward to hearing how this works out for you.
Post by earnric on Oct 23, 2021 1:09:05 GMT
Hi, I have a Yanmar 4JH3E with the simple control panel (only tachometer, alarms and then a gauge with engine hours and another with fuel level) and I'd like to connect engine data to a Raymarine multidisplay I have available to read NMEA Data like: • Engine Hours • Engine RPM • Oil Pressure • Oil Temperature • Coolant Pressure • Coolant Temperature • Percent engine load • Battery voltage and current • Alternator potential and current • Total Fuel vol • Total Fuel % • Fuel rate With those data and my Multifunction Display then I'll be able to setup: • Est. Fuel Remaining • Fuel Used (Trip) • Distance To Empty • Time to Empty • Engine and transmission warnings and alarms I'm thinking to add a Engine Gateway YDEG-04 from Yacht Devices: yachtdevicesus.com/products/engine-gateway-ydeg-04 with the Yanmar adapter cable: yachtdevicesus.com/products/adapter-cables-for-ydeg-04-engine-gatewaysAnybody knows if the Engine transmit all those data by default? I should add additional Engine sensors to allow the engine to transmit all this data? Did you get this working? I too would like more engine info on my raymarine display. How difficult was it? I don't even have engine hours! Rick
Post by nettuno on Oct 25, 2021 17:37:40 GMT
Hi Rick, I didn't do it yet. I have it in my todo list. As soon as I have it I will share how it works
Post by earnric on Oct 28, 2021 2:20:38 GMT
Hi Rick, I didn't do it yet. I have it in my todo list. As soon as I have it I will share how it works Awesome! Thanks... Rick
Post by sunrise4 on Oct 28, 2021 17:38:03 GMT
A bit different setup, but I installed the YDEG-04 from Yacht Devices along with their adapter cable to our Yanmar 4JH45 and B&G Zeus2 with a NMEA 2000 network. The adapter cable plugged into the service port on the back of the engine, and I had to run a NMEA 2000 cable with the right interface plugs to a nearby NMEA 2000 hub. The installation was straight forward and the new data showed right up on the B&G MFD. However then I learned that this does not keep track of fuel consumption. For this I added the Fuel Data Manager from Lowrance/Simrad/B&G. Borrowing from the list from Nettuno, here is what I get:
• Engine Hours - yes • Engine RPM - yes • Oil Pressure - don't know. I don't have a pressure sensor on our engine • Oil Temperature - don't know • Coolant Pressure - don't know • Coolant Temperature - yes • Percent engine load - yes • Battery voltage and current - voltage yes, but not current. Voltage was there before installing any of the above. • Alternator potential and current - don't know • Total Fuel vol - yes with Fuel Data Manager • Total Fuel % - don't know if in % • Fuel rate - yes, per hour and also per NM either based on SOG or STW
• Est. Fuel Remaining - yes with Fuel Data Manager • Fuel Used (Trip) - yes with Fuel Data Manager • Distance To Empty - yes with Fuel Data Manager • Time to Empty - don't know • Engine and transmission warnings and alarms - don't know. These are still coming from the engine control panel in my case.
Hope this all helps a bit...
Cheers!
Post by nettuno on Dec 6, 2021 10:35:42 GMT
Hi Sunrise4, do you have a picture of the plug of the service port on the back of the engine? I'd be great to know if it's the same of the 4JH3E engine...
Thanks!
Post by sunrise4 on Dec 7, 2021 0:07:44 GMT
Nettuno, before I installed the YDEG-04 from Yacht Devices (with its adapter cable) the orange connector in the first picture was connected to the grey connector shown above the green connector. These connectors are mounted on the side of the engine control unit (in my case on the starboard side of the engine and aft of the ECU). Note that the grey receptacle connector has no wires attached to it as the orange connector I believe is just intended for diagnostic purposes. The back of the orange connector (I think it is called a 'Deutsch' type of connector) has 4 wires connected to it. There is a green wire hidden behind the yellow wire in the picture. The orange connector is then plugged into the Yacht Devices adapter cable and the other end of the adapter cable is plugged into the YDEG-04 device. Note my engine is a Yanmar 4JH45, so your setup is likely different.
Hope this helps!
Post by pallotta on Aug 15, 2022 14:56:40 GMT
Hi, I have a Yanmar 4JH3E with the simple control panel (only tachometer, alarms and then a gauge with engine hours and another with fuel level) and I'd like to connect engine data to a Raymarine multidisplay I have available to read NMEA Data like: • Engine Hours • Engine RPM • Oil Pressure • Oil Temperature • Coolant Pressure • Coolant Temperature • Percent engine load • Battery voltage and current • Alternator potential and current • Total Fuel vol • Total Fuel % • Fuel rate With those data and my Multifunction Display then I'll be able to setup: • Est. Fuel Remaining • Fuel Used (Trip) • Distance To Empty • Time to Empty • Engine and transmission warnings and alarms I'm thinking to add a Engine Gateway YDEG-04 from Yacht Devices: yachtdevicesus.com/products/engine-gateway-ydeg-04 with the Yanmar adapter cable: yachtdevicesus.com/products/adapter-cables-for-ydeg-04-engine-gatewaysAnybody knows if the Engine transmit all those data by default? I should add additional Engine sensors to allow the engine to transmit all this data? Hello I am trying to do the same think. Did you find a solution ? Does it works ? Thanks to share your exprience.
Post by wolferich on Sept 11, 2022 16:21:46 GMT
Does someone try with a 4JH5E?
Post by wolferich on Sept 26, 2022 9:17:23 GMT
I talked with YachtDevices in the meantime and they informed that the 4JH5E does not deliver the needed digital data.
Post by andreshs1 on Dec 23, 2023 2:57:51 GMT
Hi all I know that it is an old thread, but trying my luck here Anyone managed to install this in the 4JH3E engine? if so, how? I made the BIG mistake of taking the information from Yacht Devices as valid, and buying the Engine gateway and Yanmar adapter cable, as their documentation states that it is compatible with the 4JH engines, but I cannot figure out where to plug it now Thanks in advance. Regards Andres
