Post by tupelo on Mar 19, 2021 8:43:12 GMT
What type of paint to use on the cast iron keel?
Post by sitara on Mar 19, 2021 21:12:27 GMT
Short answer - epoxy. Long answer check with a paint manufacturers website for their details on surface preparation. I used Norglass information when I painted a keel a few years ago (https://www.norglass.com.au/how-to). If I remember correctly the base layer was a tar-epoxy that remained somewhat soft. My old boat is still in the club and the keel looked good last time I saw it.
Post by jy51 on Mar 20, 2021 8:39:18 GMT
Don't forget the preparation!
You can use many types of underwater paint, but unless you prepare the surface correctly it will not last long.
Most keels with rust streaks and peeling paint are the result of inadequate and poor preparation.
Post by MartyB on Mar 23, 2021 1:27:32 GMT
I ground down to bare iron. Initial coating of galvanized paint by Petit Then fairing material. sand and fair to specs you want. Epoxy undercoat bottom paint of you choice
Post by deanpearl71 on Apr 8, 2021 9:43:22 GMT
Short answer - epoxy. Long answer check with a paint manufacturers website for their details on surface preparation. I used Norglass information when I painted a keel a few years ago (https://www.norglass.com.au/how-to). If I remember correctly the base layer was a tar-epoxy that remained somewhat soft. My old boat is still in the club and the keel looked good last time I saw it. I think epoxy resin is the answer to many many questions
