Post by sailingabe41ds on Mar 5, 2021 2:34:06 GMT
Hi... Can the interior light on 2015DS light bulb be changed. My older fixture the glass would come out but this one does not. Is it a sealed unit or do I force the round glass off? Trying to replace with different colored lights. Thanks Abe
Post by puravida35 on Mar 5, 2021 14:01:04 GMT
I don’t the believe the bulb can be removed from the base, it seems to be a sealed unit.
I lost a few to a “high voltage” event (lightning strike) and bought replacements through the spare parts website. I think the cost around $20.
Post by sailingabe41ds on Mar 5, 2021 15:09:38 GMT
Thanks.. Abe
Post by ianpowolny on Mar 5, 2021 20:23:38 GMT
Post by jy51 on Mar 6, 2021 8:20:04 GMT
Now that Jeanneau have gone over to LED lighting for all applications on the boat, they are using sealed units rather than replaceable bulbs.
I found this out when thinking of replacing my top of mast anchor light with an LED bulb fitted with built in daylight sensor that I had purchased for my previous boat but never got around to fitting.
Post by fimacca on Mar 6, 2021 9:30:51 GMT
That seems silly. They do have a burn life, and it is not as long as the makers say! Like all mass boat producers, cost is the driver.
Post by sailingabe41ds on Mar 6, 2021 15:10:27 GMT
I bought led lights that change from white to red if you turn the switch on off 3 times. i though to use it for night cruising. well....when i started to replace the bulbs i got stuck on the lense not coming off. abe
Post by Tafika II on Mar 6, 2021 16:58:50 GMT
Hi Abe! We replaced 6 of the factory-installed halogen lights in 2018 with Ventura ILIM30451 PowerLED Bi-Color - Stainless Steel Warm White/Red. Two in the salon, 1 in each head, one in the forward cabin, and two in the aft cabin. They are great lights (and expensive), but you can function at night with only the red-lighted. In 2020, we replaced the remaining fixtures with touch-on-off-dim warm white LED fixtures bought on Amazon. We like these combinations so we can control the brightness and task areas lighted. It not a complicated project. If you can do what you did with the water leak, you can certainly tackle this project. Are you in MDR?
Post by sailingabe41ds on Mar 6, 2021 18:42:19 GMT
Hi Abe! We replaced 6 of the factory-installed halogen lights in 2018 with Ventura ILIM30451 PowerLED Bi-Color - Stainless Steel Warm White/Red. Two in the salon, 1 in each head, one in the forward cabin, and two in the aft cabin. They are great lights (and expensive), but you can function at night with only the red-lighted. In 2020, we replaced the remaining fixtures with touch-on-off-dim warm white LED fixtures bought on Amazon. We like these combinations so we can control the brightness and task areas lighted. It not a complicated project. If you can do what you did with the water leak, you can certainly tackle this project. Are you in MDR? Thanks... That is very helpful and I will be replacing mine too. I am in Channel Islands Harbor in Ventura. If you never been up here you should try the Channel Islands National Park . It is a wonderful place to go sailing. Abe
Post by NZL50505 on Mar 6, 2021 19:37:16 GMT
Q: How many Jeanneau owners does it take to change a lightbulb? A: 3. One to navigate the Jeanneau parts order website, one to check the Jeanneau owners forum hints & tips and one to buy the Jeanneau. 😊
Post by sailingabe41ds on Mar 6, 2021 20:31:59 GMT
Q: How many Jeanneau owners does it take to change a lightbulb? A: 3. One to navigate the Jeanneau parts order website, one to check the Jeanneau owners forum hints & tips and one to buy the Jeanneau. 😊 I thought it was 1001....1 to hold the light bulb and 1000 to turn the boat round and round. Silly joke. Abe
Post by sailingabe41ds on Mar 17, 2021 2:20:03 GMT
I bought the lighs mentioned by Tafika.. the 4 pack dimmable.. and added strip lights above the grab handles which are dimmable has 42 colors and remote. abe
Post by zaphod on Mar 17, 2021 2:44:25 GMT
I bought the lighs mentioned by Tafika.. the 4 pack dimmable.. and added strip lights above the grab handles which are dimmable has 42 colors and remote. abe I am looking for rgb strip lights like you have, can you post a link to the ones you got? Was it a bulk roll that you can cut to length or just a set length?
Post by sailingabe41ds on Mar 17, 2021 5:37:41 GMT
Hi.. Hopefully I did this right but the product is Daybetter 32.8ft led. I do not think you can cut them and if you do you may need some type of adapter ..not sure. I connected it to the 12v directly instead of using the AC/transformer. The system remembers the last setting so when you turn on the electrical back on the lights go on to whatever dim and color setting you have. www.amazon.com/gp/product/B07JN28KP3/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1Abe
