Post by sharpe on Feb 23, 2021 18:58:17 GMT
Hi Can someone tell me where the boat/hull identification number is on a Sun Odyssey 32i Many thanks Steve
Post by Tafika II on Feb 23, 2021 19:18:24 GMT
Normally starboard side just forward of the transom about 1" down from where the deck joins the hull. There is also one in the engine compartment but that seems to vary by boat.
Post by NZL50505 on Feb 23, 2021 20:29:01 GMT
I went through this recently. It was almost impossible to read the number on the transom but you can try a piece of paper + pencil to rub the contours. It might be much simpler to check the engine room abs find the plate somewhere around the base of the engine near the mounts.
Post by sitara on Feb 23, 2021 21:07:08 GMT
Or on the transom itself, starboard side an inch or two down. it will be faint etching in the gel coat.
