Post by mark54 on Dec 6, 2020 14:57:42 GMT
hello I am new to this forum, renew Tonic 23 with centerboard. He is already 32 years old I need information about the distance from the stern, the trailing edge of the ballast should be fitted. And at what distance from the stern is the rotation axis of the plate. Can anyone help me. MM
Post by rene460 on Dec 7, 2020 11:32:08 GMT
Hi Mark, welcome to the forum, you will find lots of good information and friendly like minded sailors here.
I don’t have specific information on the tonic centre board system, but if you type Tonic into the search box at the top of the forum, it will bring up a number of posts on that model. Some of these include links to get a copy of the manual, and one of the posts mentions the centreboard drawings in particular.
I suggest the first thing is to chase down a copy of the manual, it may answer your questions, at least in part.
Post by mark54 on Dec 7, 2020 19:00:50 GMT
Thank you rene, I have these drawings, but they are not accurate enough to properly install the ballast.
The local seller informed me that Jeanneau would not give me such instructions because they had such rules. He proposed to buy a new ballast but this does not solve the problem because my Tonic had finkil before. I found ballast on the secondary market but without a drilled axle. So I am looking for a Tonic owner who could measure these two dimensions on your yacht.
Post by MalcolmP on Dec 7, 2020 19:31:52 GMT
Post by rene460 on Dec 8, 2020 11:11:31 GMT
Hi Mark, if I understand correctly, you have a tonic 23 that was originally fitted with a fixed keel and are converting it to the lift keel style.
That would certainly require the accurate dimensions you are requesting. It is quite a challenging project.
I assume that by “ballast” you mean an external stub keel which also houses the centre board. This is very similar to the arrangement on my SO30i, so some of the associated systems may be helpful, but certainly the location of the external keel and the centreboard pin are specific to the model, so I cannot help there.
I do hope that one of the Tonic 23 owners on the forum does come in with some information for you, either here or on the Facebook forum. It’s an interesting project and I hope you will stay in touch and tell us about your progress as you go.
Post by mark54 on Jan 11, 2021 20:14:56 GMT
Yes you are right. Balast is a Polish name for external stub keel
The purchase of a new device is not possible due to the cost of transport to Poland.
Jeanneu shared some drawings with me (https://photos.app.goo.gl/F1cGpRY6JB2wTjX67).
However, I do need the dimensions A, B, C, D.
I especially care about the dimensions C and A.
My daughter volunteered for the group Malcolm wrote about but we don't have any answers yet.
On the feacebook I found the owner of Tonica 23 from France who wants to help me, unfortunately the boat is in the water and it will be lifting it in 2-3 months.
Maybe there is someone from a closed group in this forum who could ask a question on my behalf.
Thank you for your interest in my problem.
Post by apollo on Feb 4, 2021 17:26:31 GMT
Hi Mark, I have a Tonic with center board. I can help you. But need to go to the dock first. However, the distance C is from back of the keel to the swivel, 127 cm. And 25 from the Bottom.
Post by MalcolmP on Feb 4, 2021 18:16:16 GMT
I found ballast on the secondary market but without a drilled axle. Hi Mark Glad that Apollo has now given you some dimensions. Is the second hand ballast you have found the complete stub keel plus the centreboard plate? I hadn't fully appreciated you were switching keels until I just saw you photos. These are very helpful. I hope you don't mind but I have added then to the Tonic Photos here: goo.gl/photos/FXxk4BG71zMdRRRK6 as they are bound to be of value to other Tonic owners in the future. Hopefully you will be able to get useful information from the Tonic owner in France as well as the French Tonic Facebook group. Do keep us informed of your progress. Malcolm
Post by mark54 on Feb 5, 2021 19:37:32 GMT
Hurray !!! Thank you Apollo for the dimensions. I thought I would have to 3D scan the hull of the yacht and then design a new keel.
If you can measure the C and E dimensions, you'll save me a lot of work.
Malcolm The second hand keel was too small for its proper weight. The photos in the folder are public so you can share them. I am committed to posting the reconstruction report.
In the past, I have built 3 small yachts (5.5-7.6 m) from scratch, so I hope to be able to successfully complete the renovation despite my age.
Sorry for my google-english
Post by apollo on Feb 12, 2021 8:12:05 GMT
I believe I've got them all: A= 207 cm B = 168 cm C = 127 cm D = 35 cm
Also added distance from stern (while I was at the spot) 272 cm and
already posted distance from bottom to swivel point = 27 cm
And to be complete: the thickness or witdh of the keel was app. 18 cm at the level of the swivel point (few cm more at the front end and minimal (1-2 cm) at the back off course
Please be aware that the front end of the keel is rounded, so the measures where not exact, +/- 5 cm for the A & B distances.
I realise it leaves you with a uncertainty of the "slope" of the front end of the keel. But I guess that will not make too much difference in the end
Post by MalcolmP on Feb 12, 2021 10:23:24 GMT
Post by apollo on Feb 12, 2021 11:52:03 GMT
Thanks MalcolmP, This is useful when ordering spares (if they're still out there)
Post by mark54 on Feb 16, 2021 12:06:26 GMT
Apollo you don't even know how grateful I am. These dimensions allow for the correct construction of the device. You saved me a lot of work.
