Post by Gio on Oct 21, 2020 19:35:15 GMT
Dear fellow 895 sport/marlin owners, have you noticed the same issue I face? When I deploy the full bed config in the front cabin, i am not able to open the door anymore, see pic below. Basically i cannot go out unless I remove the full bed wich is not the way it should work. I reported this issue to Jeanneau and waiting for a feedback, but I wonder if someone has already faced and solved this issue.
Post by nc on Oct 21, 2020 22:54:31 GMT
Hi, I noticed it on 2x 2020 model,but on the web on 2 videos there are an evidence of a sliding door closing from starboard to portside.
Post by nc on Oct 21, 2020 23:24:09 GMT
Merry Fisher 895 Marlin ǀ Trio Online Deniz Şöleni BÖLÜM 6 If you look at that video, you will noticed the problem, doors are almost opened, but your case is worst. About sliding door, there is a video of the prototype, at the beginning of the video you can see on the starboard blank engine plate "prototype" and on the aft sliding door " nouveauté ", in that video there is an evidence of a sliding door.
Post by nc on Oct 21, 2020 23:32:01 GMT
I noticed that the second step ( wiper tank is under first step) is partially supported on the 3rd side only, by walking on the nose's step the feeling is weak. Easy to fix for a good carpenter.
Post by Gio on Oct 22, 2020 6:00:19 GMT
Merry Fisher 895 Marlin ǀ Trio Online Deniz Şöleni BÖLÜM 6 If you look at that video, you will noticed the problem, doors are almost opened, but your case is worst. About sliding door, there is a video of the prototype, at the beginning of the video you can see on the starboard blank engine plate "prototype" and on the aft sliding door " nouveauté ", in that video there is an evidence of a sliding door. Can you send me the video with the sliding door prototipe. Unfortunately i dont think I can retrofit it. I have seen another video where the door is a single piece, and opens to the outside. Not the best solution but i think I could retrofit that one.
Post by Gio on Oct 22, 2020 6:05:50 GMT
I noticed that the second step ( wiper tank is under first step) is partially supported on the 3rd side only, by walking on the nose's step the feeling is weak. Easy to fix for a good carpenter. Yes, the second step feels weak and does creaky noises and feels is about to break. Easily fixable. Also other issue is the steps are very edgy and tend to cut....I got a cut under my feet there. I may smooth the edges as it is potentially dangerous
