Post by raybees on Oct 5, 2020 10:17:00 GMT
Attachment DeletedAny thoughts on this, hull to matrix joint is cracking, not particularly good photograph but the dark line in the lower bilge shown is actually a crack, I am told in the gel-coat. Is this normal or signs of trouble to come.
Post by raybees on Oct 5, 2020 18:28:33 GMT
68 views and not a comment, would someone just confirm they can see the photograph, not sure if I posted it correctly
Cheers Ray
Post by jy51 on Oct 5, 2020 18:49:01 GMT
Sorry the picture is not very clear. But this Is not the hull we are looking but a box section glassed into the hull as a an insert tray section, is this a deep structure crack or just a stress crack. Importantly is there any flexing of the keel to hull join?
Post by Tafika II on Oct 5, 2020 19:15:42 GMT
Need a much better picture and what boat we are talking about to comment.
Post by NZL50505 on Oct 5, 2020 21:02:10 GMT
Boat looks like a 42DS?
Post by Mistroma on Oct 5, 2020 23:15:55 GMT
Yes, looks like a 42DS. A closeup and arrow showing the crack would help.
Post by sailbleu on Oct 6, 2020 6:01:55 GMT
Does this bottom section also have a drain to the bilge pit ? Not vissible on the picture . If not , clean the area and pour in a load of epoxy This is not a crack in the hull , but a joint of hull and box that released .
Post by uli057 on Oct 6, 2020 7:08:24 GMT
Hello. These are inserted boxes, they can be repaired in case of cracks. Sand cracks and fill them with epoxy, sand and finally apply Gelcoat. The floor surface is from the hull and has nothing to do with the used boxes. The frames are glued flat to the hull.
If you like, you can additionally protect the floor surface, provided there are no keel bolts, by laminating three layers of fabric with epoxy resin.
Regards Uli
Post by raybees on Oct 6, 2020 7:52:52 GMT
Correct, !!From that picture!! You have Jeanneau obsession! Cheers Ray
Post by raybees on Oct 6, 2020 7:59:20 GMT
Yes, looks like a 42DS. A closeup and arrow showing the crack would help. Yes, Correct, Sorry no other photo's available. CheersRay
Post by raybees on Oct 6, 2020 8:31:57 GMT
Thank you for all the replies. I was under the impression that the box sections were the "Matrix" that is bonded to the hull and was therefore worried if they were parting company could be signs of damage or a serious problem. Unfortunately I am not near the boat and with the travel restrictions it is not easy to get there and asses the size or depth of crack myself. From the replies it sounds like it is a fairly simple fix, I like the idea of a couple extra layers laminated in there also.
Cheers Ray
Post by NZL50505 on Oct 6, 2020 22:58:47 GMT
This might show it better (click on image to enlarge a little bit)?
Post by raybees on Oct 7, 2020 10:11:29 GMT
Thank you, that is brilliant shows it really well.
Can anyone tell me the make up of the ribs that are forming the bilge cavities are they an open box or some former, i.e. wood, encapsulated in GRP that are then bonded in place?
Cheers Ray
