Post by jmenzler on Sept 1, 2020 19:15:55 GMT
Hello together, today the depth sounder on my 2011 SO 44i died. It's an Airmar ST200, so speed, depth & temp included. It looks like, the ST200 is no longer available ... did anyone know about a replacement? A transducer, that fits into the existing thruhull? Many thx in advance, jan h.
Post by zaphod on Sept 1, 2020 20:30:04 GMT
Hello together, today the depth sounder on my 2011 SO 44i died. It's an Airmar ST200, so speed, depth & temp included. It looks like, the ST200 is no longer available ... did anyone know about a replacement? A transducer, that fits into the existing thruhull? Many thx in advance, jan h. Are you sure the ST200 is your problem? As far as I can see the ST only does Speed and Temp. It is the DST triducers that do Depth, Speed and Temp. Are you sure you don't have a separate depth transducer?
Post by jmenzler on Sept 2, 2020 9:28:35 GMT
Post by jmenzler on Sept 2, 2020 11:17:21 GMT
Actually found the label with the part number... it's a DST800!? But recognized as a DST200 ... Anybody knows if the DST800 is still available?
Post by Tafika II on Sept 2, 2020 15:11:10 GMT
Google "DST800" and you will find lots for sale
Post by zaphod on Sept 2, 2020 15:44:00 GMT
Yes, the manual you posted is for a DST200 not an ST200.
Yes you can still get the DST800, I just replaced mine a few months ago.
Just make sure you know which type you have. Some of them are analog and connect to an external digital converter, and others do the digital conversion internally and connect straight to the Seatalk network.
