Post by sfh on Jul 31, 2020 12:56:49 GMT
Hi All,
We have a Jeanneau 53 with three A/C units. All units are discharging the condensed water into the bilge.
When humidity is high the result is that the bilge pump runs frequently which can be quite annoying during the night.
I believe there was a post about this a year or two ago with ideas for a solution to this problem but I am unable to locate it.
Anyway, good ideas to resolve this would be highly welcome
Steen
Post by ania on Jul 31, 2020 13:41:48 GMT
Hi All, We have a Jeanneau 53 with three A/C units. All units are discharging the condensed water into the bilge. When humidity is high the result is that the bilge pump runs frequently which can be quite annoying during the night. I believe there was a post about this a year or two ago with ideas for a solution to this problem but I am unable to locate it. Anyway, good ideas to resolve this would be highly welcome Steen Same issue on Jeanneau 51. We hade little red pumps that pump condensation out. Absolutely unreliable pieces of junk. Here’s your solution, works like a dream: www.mmair.com/marine-division/accessories/mermaid-condensator/
Post by zaphod on Aug 2, 2020 7:21:50 GMT
You could capture it. Condensate from an A/C system is pure clean water. You could use it, or just pump it out at a less annoying time!
Post by alex1949 on Aug 4, 2020 14:35:50 GMT
Hi All, We have a Jeanneau 53 with three A/C units. All units are discharging the condensed water into the bilge. When humidity is high the result is that the bilge pump runs frequently which can be quite annoying during the night. I believe there was a post about this a year or two ago with ideas for a solution to this problem but I am unable to locate it. Anyway, good ideas to resolve this would be highly welcome Steen Hi sfh, Your bilge pump is kipping hunting, it pumps water out of the bilge but since pump is above bilge level, water that remain in the pipe just go back and reactivate the pump sensor again and again. You can solve it easily by deploying a simple Bruss one way valve at the end of the bilge pump pipe . Get such valve for a couple of $ at any home store. Very efficient.
Post by zzmeyer on Aug 17, 2020 17:26:50 GMT
I have six air conditioner units on my catamaran and they all empty into a sump with a bilge pump type pump. Works like a charm. The shower also drains into it so no need for a button in the shower to pump water ovarboard. About $100 at Defender www.defender.com/product.jsp?id=2100903
Post by tsenator on Sept 3, 2020 15:21:06 GMT
Hi All, We have a Jeanneau 53 with three A/C units. All units are discharging the condensed water into the bilge. When humidity is high the result is that the bilge pump runs frequently which can be quite annoying during the night. I believe there was a post about this a year or two ago with ideas for a solution to this problem but I am unable to locate it. Anyway, good ideas to resolve this would be highly welcome Steen On my old boat I bought a "venturi fertilizer injector" which uses "venturi suction" from the cooling water flow to "suck out" the AC water in drain pan. No electricity needed. It worked very well . Its the same principal they used to suck "liquid fertilzer" into a spray hose. They come in all hose sizes so you will need to find one that works for you. You really don't need much suction flow. When the pan is "dry" and the venturi injector is sucking air you will know as your AC water squirting out the side of your boat will look more like a foam than a clear jet stream.
