Post by top on Jun 29, 2020 14:06:29 GMT
Hi, i would like to replace the anchor light with a new one LED on my SO349 but I cannot find any specification on the lamp. Does anyone know anything about it? Thks
Post by rksailsolo1 on Feb 13, 2021 20:01:47 GMT
Jeanneau has an online parts list where you can research
Post by pbaumann on Feb 14, 2021 1:36:58 GMT
What’s the web address for the JEANNEAU parts directly?
Post by ianpowolny on Feb 14, 2021 18:25:57 GMT
elcid
Post by elcid on May 19, 2022 12:30:33 GMT
Would this be compatible with a 2005 Sun Odyssey 40.3? Very cool. I'm looking to replace all lights with LEDs, and I am trying to research what I should order. If anyone has done this before, please share the knowledge.
Post by ohana on May 19, 2022 21:30:14 GMT
Personally, I think masthead anchor lights are almost a complete waste of time. I recall a really scary experience of entering an anchorage in Gigha (West of Scotland) on a dark night where from a distance I was faced with a number of high masthead anchor lights. Getting closer to the boats in the anchorage, it was almost impossible to relate these high lights to the dark boat hulls at water level; indeed close up many of the lights disappeared, shielded by the top of the mast! The boats were in darkness as everyone was asleep. The only boats which we could easily distinguish were ones with a anchor/riding light set up approx 2M from deck level.
On a separate occasion, I was anchored in Bunessan on Mull (again west of scotland) which is a bay with a small pier at the head. There were around 30 other boats, most only used mast head anchor lights. During the night, a fishing boat came in at speed to land a catch at the pier, hit and badly damaged an anchored wooden boat which had only a masthead anchor light on.
I have replaced my masthead anchor light with a tricolour for night sailing. I carry a separate LED anchor light which is tied using some small rope between the genoa and the mast, around 2M off the deck, with a trailing wire back to the power socket in the cockpit. I sleep much better with this setup!
ronparker
Jeanneau Model: 2002 SO40
Yacht Name: Jessabbe
Home Port: Gippsland Lakes, Victoria
Post by ronparker on May 21, 2022 13:02:02 GMT
Some useful information in this article: link
Some advice offered by marine electricians is to avoid fitting LED bulb replacements due to corrosion issues, water ingress, loose bayonet sockets etc and simply install new sealed LED light fittings, particularly for weather exposed lights.
