Post by lateron on Jun 17, 2020 18:54:34 GMT
Hi folks, Not posted for a while. Can anyone tell me for sure if the battery charger on my Jeanneau Sun Odyssey 32 2004 charges both batteries or just the house battery as I suspect my start battery is not being charged when plugged into shore power. Am I doing something wrong ?
Best wishes Ron
Post by so32foot on Jun 17, 2020 19:36:58 GMT
Should be both. You should measure the voltage on both batteries with and without loading. It might be that the start battery is not OK.
Post by lateron on Jun 17, 2020 22:23:01 GMT
OK thanks. I'll have another look at it . It was just the guy next to me who has a dufour 32 said his system only charged the one battery.And you're correct the start battery is now kaput. Ron
Post by lateron on Jul 3, 2020 18:16:40 GMT
Hi again, Well, referring back to my query as to whether both batteries are charged I have found the answer. In removing the old and fitting a new battery I discovered a red lead had come adrift from the engine battery. Reconnected it and now the charger is again charging both batteries!! The mystery lead had disappeared up its conduit so to speak! Anyway mystery solved.
Cheers Ron
