wildflower20
Jeanneau Model: SO 409
Yacht Name: Wildflower
Home Port: Rock Hall, MD
Post by wildflower20 on Jun 15, 2020 20:24:14 GMT
Hi, Anyone have any advice/ recommendations for an autopilot for a 2012 SO 409? I'm just wondering what folks have already installed and the ease of installation. Thanks, Chris
Post by Tafika II on Jun 16, 2020 0:24:04 GMT
It depends on what other electronics are on the boat. Garmin, B&G or Raymarine should be matched with auto pilot
wildflower20
Post by wildflower20 on Jun 17, 2020 10:05:19 GMT
Thank you. Sorry, everything is Raymarine. Just trying to figure out which model/ size + drive unit. Chris
Post by moonshadow on Jun 17, 2020 12:54:09 GMT
On my 469 I have the Raymarine autopilot. I believe it is the EV-400. I suspect that your Raymarine dealer or tech support would recommend the best unit for your boat. Mine works very well to hold heading, follow a course to waypoint(s), and a set wind angle. Seems to use very little battery power considering the work it does. One important item is to keep your heading sensor well calibrated. Otherwise it seems to hunt around a lot trying to hold a course. Heading is easy since it locks on to wherever the boat is pointed when turned on. Of course it has some trouble keeping up in big following seas, but I keep mine on a medium sensitivity setting. I’m happy with it. 2014 installation and no problems yet.
wildflower20
Post by wildflower20 on Jun 18, 2020 11:55:36 GMT
Many thanks Moonshadow!
petros42
Jeanneau Model: SO 419
Yacht Name: Pole Dancer
Home Port: Gabriola
Country: Canada
Post by petros42 on Jun 22, 2020 15:56:48 GMT
On my SO 419, I have the Raymarine autopilot. I don't have the model of the hydraulic drive but here are the rest of the bits:
Autopilot Course Computer Raymarine EV-1 Autopilot Control Raymarine p70s Autopilot Drive Raymarine Autopilot Actuator Raymarine ACU-400
I've been happy with the system so far. The helm is well balanced, so the drive doesn't have to work that hard. The only think I've noticed that I don't like, is when I set a new course, if I'm not close to the expected course, it makes a hard adjustment to get on course and overcompensates. My workaround to this is manually get on course before engaging the pilot.
If you would like any photos of the installation, let me know.
Post by chuckr on Jun 27, 2020 18:45:00 GMT
SoulMates is a 2000 DS40 and came with a RayMarine suite of products. She has I think the 6002 -- i think - and for the past 14 years i have been underway and OTTO PILO does most of the driving. I have sailed both sides of the Caribbeann -- 2 Atlantic crossings, most of the Med and i do mean most,and all the Black Sea. It does a great job -- the only issue is when there are short steep seas on the stern and then it tries but i generally turn if off and hand steer. But say that in big swells it workd great -- came back across the Atlantic in seas of 12-15' on the stern and OtTO did a good job
Post by gtitarenko on Feb 22, 2021 19:24:23 GMT
Hi, I feel this is the right thread to ask a follow up question..
I consider installing Raymarine Autopilot on my SO 409 2012. Chartplotter C90 W /Radar/wind/depth all Raymarine original, so Autopilot will be Raymarine. I'm told EV-400 is the only current Raymarine Autopilot which would fit this boat?
Is this true?
Can't EV-200 go on SO 409 2012?
Thanks in advance, -George
Post by element on Feb 23, 2021 6:09:02 GMT
An EV-200 can only power a T1 linear drive unit. I believe the T1 is spect for a boat with max total weight of 11.000 kg. I guess a 409 will be fully loaded will be around 10.500 kg so should be possible.
Post by gtitarenko on Feb 23, 2021 17:19:58 GMT
Thank you , this is what I was told by the technician which I contacted. I also raised this with Raymarine Tech Support and if they respond, I will share their reply here too.
Thanks again
gtomi
Post by gtomi on Mar 7, 2023 12:25:38 GMT
Hi petros42!
I would like to request photos of the installation! I am especially interested in the drive part. What kind of drive does it need?
Post by Elcano on Mar 9, 2023 7:58:37 GMT
Hi, we have a Simrad autopilot (AC42, originally equipped) on our 2012 SO409. Works flawlessly.
