Post by frankyan on Mar 20, 2020 12:39:52 GMT
My Sun Odyssey 34,2 is undergoing major repair and I have been told by the yard that new keel bolts are required and they need to know the grade of metal used .Can anyone give me a direction as to how to get this info.
Frank
email...frankpharm@hotmail.com
Post by andreshs1 on Mar 20, 2020 14:34:48 GMT
I got mine from the Jeanneau dealer, I would advise you to do the same
cheers
Post by zaphod on Mar 20, 2020 16:03:48 GMT
I can't help but wonder how qualified the boat yard is to be replacing keel bolts if they don't even know what grade is appropriate for the application.
Post by Charlie-Bravo on Mar 20, 2020 20:29:03 GMT
Hi, you mention .. major repairs .. is this due to a hard grounding? if not they are not likely to require replacement.
The choice of keel bolt material is generaly a small issue, and a personal choice, 316 stainless is subject to crevis coronation but doesn't rust much, mild steel is arguably a stronger choice, but does need coating in a bedding material and the exposed ends need paint, both work well and are stronger than the hull they are bolted on to, both will last 30 or more years as long as they don't have sea water attacking them through the keel to hull joint.
Post by ianpowolny on Mar 21, 2020 10:15:53 GMT
Jeanneau Client Services have this email address: service.client@jeanneau.fr
I’d suggest you contact them. They take a while to answer but they should give you the correct information. I’d also ask about tightening torque.
Ian
