Keurig on the boat - Coffee anyone!
Jul 26, 2019 23:51:25 GMT
Post by Capt’n Ron on Jul 26, 2019 23:51:25 GMT
As boaters we learn from the time we purchase the boat to every time we step on the boat.
My coffee story:
When I purchased my 795 I told the sales person at Sundance I wanted to use my Keurig on the boat, so he ordered up an inverter/Charger to be installed. Problem was every time I tried to use the Keurig it shut the inverter down. They did a fair amount of trouble shooting and kept adding house batteries (4 in total), but nothing seem to work. So I dug in and did my research and found I needed a pure sin wave inverter to run appliances like coffee boilers. As it turned out the dealer had installed a modified sin inverter (Xantrex HS 1800) which is not designed to handle loads such as motors and boilers. I had brought that to the attention of the dealer multiple times over the last couple of years, but they did nothing to resolve it. Lately I had been having issues with my battery bank losing charge too quickly so I decided it was time to take things into my own hands and replace the inverter myself with a Xantrex HFS 2055. The job was pretty straight forwarded except I found the dealer never did run a ground to the inverter so I’ve been running for 3 years with a fire hazard.
With the new inverter installed (and grounded!), I can now use my Keurig on the boat to satisfy those early fishing mornings with a fresh cup of brew!
A couple technical notes: When it runs the pre-brew it draws about 1500 watts and the voltage meter drops to about 11.8V and then pops back up to normal voltage when the boiler is done. After three cups I used about 11 amp hours (or 3Ah per cup). So plenty left on my 200 usable Ah on my battery bank. One thing to note, I had to set the battery shutdown threshold on the inverter to 10.5V instead of the middle setting of 11.8, otherwise the inverter would have shut down so be sure to keep an eye on your battery voltage meter.
Happy brewing!
Capt’n Ron
My coffee story:
Happy brewing!
Capt’n Ron
