Post by celsian on Jul 10, 2019 15:24:31 GMT
Does anyone know how to access the outlet pipe where it connects to the bottom of the holding tank? However small I might be I am not able to reach the hose clips from within the heads cupboard under the sink. Removing the outer frame from the tank surround does not seem to grant any greater access. The boat is 1999. The tank is stainless steel. Thanks
Simon Leatham, S/V Celsian
Post by geitz on Jul 12, 2019 12:05:08 GMT
The outlet at the bottom of the holding tank is the sea discharge. On my '99 36.2, it's readily accessible under the head sink. Can you attach some images?
Mike
Post by celsian on Jul 15, 2019 10:27:26 GMT
Sadly the boat is in Greece and I am in the UK! The outlet from the tank is on the far left of the tank (as you look at it) and unreachable from under the sink! I guess this must be a different build. I fear that full removal of the tank is the only option. Thanks for the response.
Simon, S/V Celsian
