Post by ajb on Apr 15, 2019 19:20:39 GMT
Just bought a MF 855. I want to get behind the instrument panel to change the plotter and radio wiring. There seems to be an access panel in the heads but it isn't easily removed. There is a finger catch but pushing it doesn't have the desired effect. Advice very much appreciated.
AJB
mcclown
Jeanneau Model: Merry Fisher 855
Yacht Name: Helenic II
Home Port: Largs
Country: Scotland
Post by mcclown on Jul 27, 2019 21:52:40 GMT
Hi, yes it’s a bit fiddly, when you press the button you need to lift the panel up at the same time and bend the panel back towards you. Once it’s disengaged at the bottom, slide the top out from two locating lugs. Hope that helps,
