Post by Gio on Sept 19, 2021 15:25:30 GMT
Bumping this post...
Any additional complaints from the factory set-up for the Sport/NC 895?
I wrote this in another post, the battery set-up from factory (starting + house) is really inadequate for what modern engines need and manufacturers recommend, actually it may causes issues and overall reliability concerns.
I rebuilt the battery system just few months back from delivery (engines start and house), and now i can say i have a very reliable set-up, i can feel the difference from the way the engines start vs before.
My boat came by default with 1x140ah flooded for engine start, and 1x140ah flooded for start+house, I had so many issues, including getting stranded few times as the power was not enough to start the engines.
Also, the length of battery cables (start to engine) are too long for what is recommended, too many parasitic losses and you leave to much power on the table.
I will post a diagram in one of my next posts.
So check your batteries and configuration if you have a dual engines boat...
mvconstellation
Jeanneau Model: NC 895 Weekender
Home Port: Shilshole Bay Marina
Post by mvconstellation on Apr 27, 2022 0:46:02 GMT
Gio, can you share a diagram or details of what you purchased? I just took delivery of a NC895 weekender, and we did not overnight, and barely had enough power the next day. Any advise would be appreciated!
Post by Gio on May 19, 2022 16:34:29 GMT
Gio , can you share a diagram or details of what you purchased? I just took delivery of a NC895 weekender, and we did not overnight, and barely had enough power the next day. Any advise would be appreciated! Hi there - the standard configuration from factory is not something i would trust. I will do a proper post when i find the time, but you can refer to this tread where i posted an high level diagram: jeanneau.proboards.com/thread/8023/895-marlin-sport-mercury-250s?page=2Key components are all mastervolt, i also added a NMEA shunt, all connected to the chartplotter via NMEA so i can monitor exactly how much i have left in the battery house. I have also used remote switchers to open and close the batteries, and also re-wired the engines batteries as the cables from factory are too long and you lose a lot of current only for this. I literally could not start the engines because of that... I will post something soon, but i can tell you this is the second season using the aircon from the engines and it has been flawless....
Post by alexrom on May 23, 2022 2:25:13 GMT
I agree with Gio (sir, please check your DMs). The original wiring could be better but it's applicable for most of the manufacturers: your boat needs you to customize it to your needs.
In my case (Miami) it's 12 months of season and regular usage. Water kept. Shore power.
I installed 2x150A LiFePo for housing. This battery bank is powered via DC-DC charger (Orion Tr 30A) from a cranking battery. Also added 'unswitched' distribution (20A) to power Victron Cerbo and Teltonika router 24/7.
2x cranking batteries just for engines and windlass. Both flooded Interstate in deep tray box just in case the poison leakage. Both monitored with Victron Smart Shunt (connected to Cerbo).
I also run a cable from the charger to the bow thruster battery (our christec has 3xAC outputs). BTW I rewired bow thruster batt too just to have Smart Shunt there.
The complication is SeaKeeper which is a beast in terms of power consumption. It has its own AGM battery that is connected via DC-DC charger (18A) to a cranking battery. During the start up it consumes ~50A and I sit in the boat for a half of an hour to compensate and charge its battery when the gyro gets on speed. I'd rather start it from my phone an hour prior (WIP).
To accommodate two additional power banks I've replaced batteries switches with ML-RBS: 1 for housing (SeaKep and House) and 1 for the engines (both cranking). While running the cables (make sure you ate your veggies and did the yoga) I left the puller cables everywhere and it paid itself when I was connecting Smart Shunts to Cerbo via VE.Direct.
The only thing I regret is Victron. I'm a software engineer and the ecosystem didn't met my expectations. All the rest is "must have" IMO.
TODO: - inverter/charger for A/C and dedicated shore power charger for housing - replace 2x150A LiFePo with 2x300A LiFePo - relocate windlass to be closer to the bowthruster and connect to the same batt - some smart relay that can be on/off via a)Victron b)any phone app
