Post by vasko on Feb 12, 2019 13:57:19 GMT
Next revision will be with support for Primary and Slave - e.g. monitoring your boat from friends/partner phone/watch when you are at the taverna
Post by pdodds on Feb 13, 2019 9:32:32 GMT
Which app are you using... there seems to be a few to choose from on Apples App Store Thanks
Post by vasko on Feb 13, 2019 9:42:49 GMT
Post by alenka on Feb 15, 2019 21:50:16 GMT
But does it use apple/goggles maps or do you have to buy the charts/maps for your area?
Post by vasko on Feb 16, 2019 7:54:09 GMT
But does it use apple/goggles maps or do you have to buy the charts/maps for your area? It uses apple map - no need to buy anything and it also show the depth if available when the anchor point has been recorded. Let me know if you want a free promo code and I can send you one
Post by alenka on Feb 17, 2019 14:11:09 GMT
I would certainly be interested in giving it a try. The one I currently have is far from good in a number of respects.
Post by timpeacockuk on Feb 17, 2019 18:12:30 GMT
Hi Vasko. I have your Navigator Pro app which has an anchor alarm module. Does that Apple Watch upgrade work with that too? Many thanks
Post by vasko on Feb 17, 2019 19:42:39 GMT
Hi Vasko. I have your Navigator Pro app which has an anchor alarm module. Does that Apple Watch upgrade work with that too? Many thanks Yep the latest upgrade is working with apple watch
Post by Don Reaves on Feb 17, 2019 23:39:47 GMT
I have Navigator pro version 3.5.9. However, I don’t see any support for an Apple Watch.
Post by vasko on Feb 18, 2019 18:36:05 GMT
I have Navigator pro version 3.5.9. However, I don’t see any support for an Apple Watch. you should be able to update to 3.9 and you will have
Post by Don Reaves on Feb 18, 2019 19:38:09 GMT
I have Navigator pro version 3.5.9. However, I don’t see any support for an Apple Watch. you should be able to update to 3.9 and you will have I see the problem. The old app is called Navigator Pro. The new one is Anchor Alarm with Late Set, which means it's not a simple update. It's a new purchase.
Post by vasko on Feb 18, 2019 19:46:12 GMT
you should be able to update to 3.9 and you will have I see the problem. The old app is called Navigator Pro. The new one is Anchor Alarm with Late Set, which means it's not a simple update. It's a new purchase. Nooooo - Anchor Alarm is sub-set of navigator Please go to AppStore and update the Navigator
Post by vasko on Feb 18, 2019 19:49:25 GMT
If you do not have update for the navigator in your country apple store - it just may take 1-2 days to apear - this is apple policy some countries are updated before others...
Post by Don Reaves on Feb 18, 2019 20:09:11 GMT
When I search for your company "B2N Ltd" in the App store (US) I see only three apps listed:
- Boat Vitals BLE
- Anchor Alarm with Late Set
- Sky Based Weather Navigator
I'll be patient and wait a couple of days to see what happens.
Post by alenka on Feb 19, 2019 9:42:24 GMT
One last quick question from me.
When used in the map mode does the circle of swing show. Ie can you set a cycle/warning in relation to what is showing on the map?
Post by vasko on Feb 19, 2019 14:52:17 GMT
- Boat Vitals BLE
Go in App Store and scroll down to refresh - you should have a update for Sky Based Weather Navigator .... the version is 3.9.3
Post by vasko on Feb 19, 2019 14:54:45 GMT
One last quick question from me. When used in the map mode does the circle of swing show. Ie can you set a cycle/warning in relation to what is showing on the map? not in this version - but working on it - w.g. to be able to define area instead of circle the next improments on teh lists are : 1. Primary/Slave monitoring e.g. leave on phone on the boat and monitor the movement from a second phone in the pub 2. Area definition on the map for anchor alarm - btw - do you want a free promo code for the app ?
Post by Don Reaves on Feb 19, 2019 22:51:19 GMT
Go in App Store and scroll down to refresh - you should have a update for Sky Based Weather Navigator .... the version is 3.9.3 Yes, this worked. I was quite surprised that the app didn't offer to update, which is what most if not all of the other apps do on my iPhone.
Thanks!
Post by vasko on Feb 20, 2019 7:33:34 GMT
Thanks!
Sometime it take aged to IoS to notify you for update...
Post by rdubs on Mar 5, 2019 18:24:15 GMT
I just bought this app, mainly for the anchor alarm. But I just opened the app and noticed this disclaimer: "The phone has to be locked and the watch unlocked on your wrist [to receive the watch alert]."
Having the phone locked is no problem, but I was really hoping to be able to have this anchor alarm go off if the boat starts drifting while I am asleep. If I'm sleeping, I think the Apple Watch will lock itself? Which means I wouldn't get the alarm. Any thoughts?
Post by vasko on Mar 5, 2019 21:52:28 GMT
I just bought this app, mainly for the anchor alarm. But I just opened the app and noticed this disclaimer: "The phone has to be locked and the watch unlocked on your wrist [to receive the watch alert]." Having the phone locked is no problem, but I was really hoping to be able to have this anchor alarm go off if the boat starts drifting while I am asleep. If I'm sleeping, I think the Apple Watch will lock itself? Which means I wouldn't get the alarm. Any thoughts? Apple is very tricky with the watch inbrief: If wrist detection is turned on, I believe the watch won't lock itself. But anyway until we find a better solution we'd recommend that you rely on the phone's alarm and not the watch.
Post by Bora on Mar 5, 2019 22:04:10 GMT
The watch will be unlocked as long as it stays on your wrist.
If you have the lock turned on then it will activate when removed from your wrist.
Post by rdubs on Mar 5, 2019 22:30:22 GMT
Many thanks. Having the phone nearby isn't a problem, I was just wanting something which would alarm if I'm sleeping in the forward berth and don't hear the anchor alarm on the MFD going off.
Post by vasko on Mar 6, 2019 10:07:06 GMT
Many thanks. Having the phone nearby isn't a problem, I was just wanting something which would alarm if I'm sleeping in the forward berth and don't hear the anchor alarm on the MFD going off. I have stopped using the MFD anchor alarm long ago and completly trust on the Anchor Alarm on my iPhone - usually save my boat about 2-4 times every summer  The thing that I was missing is to be able to have alarm while in the pub - now this can be done with the watch if it has SIM card and the new comming version with primary and slave - e.g I will be able to leave my phone on the boat and receive alarms and monitor the boat on my wifes phone., For long periods on anchor I use the boat-vitals anchor monitor
Post by rdubs on Mar 6, 2019 16:10:06 GMT
Would it be hard to have the app display the course and speed, or even just speed? Even if it's just using the phone's GPS? Right now to show the boat's speed on my apple watch I have to use Seanav or iSailor.
