pfppete
Jeanneau Model: SO-419
Yacht Name: Feng Shui II
Home Port: Yankton, SD
Country: US
Post by pfppete on Aug 7, 2018 19:39:41 GMT
Hello,
I have a new SO-419 with a furling mast and the standard 106# jib and would like to know what the settings are using a Loss Gauge...
Any help would be apricated...
Thanks,
Phil
Post by MartyB on Aug 13, 2018 0:14:55 GMT
The setting depends upon your wire size, and the guage you are using. IE, a PT2 and PT3 can both do 1/4" cable IIRC. But the 3 will have a lower number on the scale, than a 2! Also, what % of breaking strength are you setting the rig at. That too will effect what guage setting you are doing.
Not a simple here are the numbers you need!
marty
