docobdo
Jeanneau Model: SO 439
Yacht Name: Wind's Will
Home Port: Portland, Maine
Country: 04102
Post by docobdo on Jun 25, 2018 15:16:23 GMT
Post by moonshadow on Jun 25, 2018 21:15:16 GMT
I have a 469 with the jeanneau installed Cummins 7.5 kw generator installed center line aft most hatch just in front of the folding swim platform. It looks like it is in its own box and placed into the insulated area. Very quiet and easy to start. The water intake is center line and the discharge of water is just below the center line. Barely hear it run and it meets all the needs so far including three A/C units. If it will fit in your boat I would recommend.
zuluwhiskey
Jeanneau Model: 439 Sun Odyssey
Yacht Name: S/V Katara
Home Port: Deltaville, VA
Post by zuluwhiskey on May 16, 2022 14:39:02 GMT
I just bought a near mint 2016 SO 439 last August, three cabin like yours.
I too am trying to find a genset solution to run AC (some or all 3) in he summer on the hook in the Carolinas.
I am also installing an arch and 1200watts of Solar with AGMS.
Did you ever choose a generator and how did you install it if you did?
Sincerely, Zack Worrell
S/V Katara Deltaville, VA
Post by NZL50505 on May 19, 2022 0:01:21 GMT
If you consider re-directing a potential Genset investment into a large enough lithium battery & inverter system supported by solar you could skip the need for a noisy heavy expensive Genset.
Look at what the Parlay guys achieved (they’re running tons of electrical kit on battery / solar):
