Post by MalcolmP on Mar 12, 2006 15:50:21 GMT
Why not let other forum members know a little more about you and your Jeanneau? it is easy to add details of Jeanneau Model, Boat Name, Home Port and Country to your profile. To do so go to "Profile", then select "Edit Profile" - then select the "Personal" tab, then scroll down to the new fields and complete. You can also further personalise your profile with an avatar image it is quite simple again select "Edit Profile" to a number of Avatar options. Either choose one of the Proboard options - or use their avatar maker, alternatively you can upload one from an external image hosting site. For example : imgur.com. Full details on using the Imgur site is at: jeanneau.proboards.com/thread/631/adding-image-post-new-procedurebut you will also need to resize your image to a max of 150 in either height or width. This can also be done on the Imgur site, using their edit tool after you have made an upload This is a screen shot example where the image has been re-sized to 150 x 113, after using their Crop/Resize option. For avatars copy the Direct Link code Then ensure your are logged into the Jeanneau forum, go to your Profile then select, “Modify Profile” Paste in the copied direct link into the Change/upload Avatar link box Scroll to bottom of the page and click “save avatar changes” Thats it!
