Post by jdathena on Apr 6, 2008 13:24:13 GMT
I would like to replace the line chocks (closed top kind) on my SO39i 2007 with the open top kind , similar to the ones installed on the 2008 models. Anyone knows the manufacture, part #, or where can they be purchased .
thanks
Post by MalcolmP on Apr 7, 2008 17:19:30 GMT
I would like to replace the line chocks (closed top kind) on my SO39i 2007 with the open top kind , similar to the ones installed on the 2008 models. Anyone knows the manufacture, part #, or where can they be purchased . thanks www.jeanneauparts.com list these fairleads/chaumard as "CHAUM.IN.FERME L200 DC1" at € 52,17 +tax each but I guess you would want the same part but "ouvert" not fermé" If you are in the States you should be able to order via Gilles at Jeanneau America I believe that it may be possible to have a competent metal worker cut and polish the closed fairlead in situ to make it open, might be worth investigating as it would be a lot less hassle if done correctly Malcolm
