Rudder
Apr 2, 2008 13:49:12 GMT
Post by kancha on Apr 2, 2008 13:49:12 GMT
Good day all!
I do have a Sun Fizz 40 that need to have the replacement of the rudder. I do know an artist that will make a new one in aluminum instead wood and fiber. I'm trying to find the plan of the rudder to make sur to follow up all things properly...someone can help?
Thanks!
Rudder
Apr 3, 2008 6:36:31 GMT
Post by Geoff on Apr 3, 2008 6:36:31 GMT
Kancha Try contacting Ian Scott at Clarke and Carter in England. They are in Burnham-on-Crouch in Essex (a Google will bring them up). They might be able to help with plans and dimensions. Good luck. Geoff.
Rudder
Apr 3, 2008 15:26:44 GMT
Post by kancha on Apr 3, 2008 15:26:44 GMT
Many Thaks Geoff...I will get in touch with them! Will give you feedback!
Rudder
Apr 3, 2008 18:06:32 GMT
Post by notorious7004 on Apr 3, 2008 18:06:32 GMT
kancha, why aluminium? I´d be careful about electrolysis if using aluminium. Wood is easier to shape and poses no electrolysis problems. If you didn´t loose your original you could use it as a template to shape the new one. Good Luck.
