Post by sitara on Mar 24, 2017 3:53:11 GMT
Here is a pic of the sliding hatch lock I installed on my SO 36i. Works very well and there have been no leaks (O-rings between the perspex and the shaft).
Post by rene460 on Mar 24, 2017 8:56:33 GMT
Hi Sitara,
That is another very elegant solution. I like the way it can be operated from outside as well as inside.
Where did the hardware come from? Or have you made it or modified parts from another purpose?
Update - sorry, I found it, should have looked at your link first. I had missed your earlier post.
Post by hoppy on Mar 24, 2017 10:59:27 GMT
Here is a pic of the sliding hatch lock I installed on my SO 36i. Works very well and there have been no leaks (O-rings between the perspex and the shaft). Nice solution. I googled the levers and I think I found the exact same unit www.westerly-yachts.co.uk/index.php?manufacturers_id=32I assume that the blue bit is a lock, so you can prevent the outside lever from opening the hatch when you are sleeping.
Post by sitara on Mar 25, 2017 20:49:26 GMT
That looks looks the fitting Hoppy, I disabled the locking mechanism as a safety issue. Those outside must be able to get inside. And Rene, I think most replacement hatch locking handles would do the job, this was what was available on the day and the price was reasonable.
