Post by MalcolmP on Dec 3, 2016 18:33:51 GMT
Just replaced the split seal on my fridge lid on my 2008 39i. These are available from Jeanneau dealers still, I got mine from Ian at Clarke and Carter for £20 inc tax and postage, so relatively good value. However things like this may go out of stock in the future, so I cut the old profile (2nd pic below) and did a search for fridge door profiles. Lo and behold what looks exactly correct is available from Scotland: www.sealitscotland.co.uk/general_profile.php Reference Arrow Head JME-322-C. Crude measurements also tally. Might be useful for someone in the future As well as splitting the seal had slightly perished in the moulding, so when pulling out left some bits which are hard to remove - the moulding is quite thin, so take care. The seal seems to simply push back into place - no glue.
Post by fakinx on Mar 16, 2017 18:14:08 GMT
MalcolmP, thanx for your tip. I was just looking for correct seal for past winter and didn't see your post. How did you join the corners? Glued or just precisely cut? Best regards.
Post by MalcolmP on Mar 17, 2017 13:37:19 GMT
I fitted the replacement from Jeanneau, so was already glued. But it looks to me like it can be cut on the mitre and glued, might have been welded, but I don't think so
Post by fakinx on Mar 17, 2017 14:23:29 GMT
Thanks for your answer. I was also looking for replacement seal on-line and it looks like there is another producer near me which also produces vacuum plates for custom made refrigerators if someone is perhaps interested... en.turna.si
Post by Bora on Jun 17, 2019 15:01:13 GMT
Seeing this I got 2 new sets of seals and installed them thinking it would solve my problem I’m having but no luck Does anyone else get a build up of condensation at the back of the fridge and freezer? It’s definitely more apparent with the fridge as it eventually frosts up the entire little freezer compartment.
Post by jdl01 on Jun 18, 2019 16:46:26 GMT
On our 379 we found that the attachment of the fridge box to the underside of the counter was not level, resulting in a leak in the door seal on one corner. We glued thin plastic shims to the offending low areas on the inner counter lip and added a continuous ribbon of freezer tape glued all around the lower counter edge. This has worked well for five years. As belt and braces, we added a 3/8" high density foam mat, cut to fit the entire counter above the fridge. It really holds the cold in the fridge as well as providing a good non slip surface when washing dishes.
Post by Bora on Jul 7, 2019 7:34:56 GMT
Will definitely need to research a bit more, the boat is in Spain and the cabin temperatures are getting to 30 degrees during the day and the fridge is struggling to get below 11 degrees. I guess the water temperature won't be helping either as i'm sure its got a cooling plate on the hull.
Away to buy a mat that I can cut to put over the surface to help with the insulation.
Post by NZL50505 on Jul 21, 2019 23:51:39 GMT
A few weeks ago someone posted their new improved fridge seal which eliminated the problem of condensation and icing of the freezer compartment. And they included a picture of the seal (which I recall was bigger / thicker than the original). I've tried searching for the thread and pic but can't find it.
Can anyone else recall the thread?
Thanks
svkalon
Jeanneau Model: Yacht 53
Yacht Name: Kalon II
Home Port: Madeira Beach, FL
Instagram: SailonKalon
Post by svkalon on Jul 25, 2019 22:34:25 GMT
We need to replace the gasket on our fridge FRONT door. Any chance you have an idea where we can get one of those? (1997 42CC)
Post by earnric on Oct 1, 2021 21:17:06 GMT
Just replaced the split seal on my fridge lid on my 2008 39i. These are available from Jeanneau dealers still, I got mine from Ian at Clarke and Carter for £20 inc tax and postage, so relatively good value. However things like this may go out of stock in the future, so I cut the old profile (2nd pic below) and did a search for fridge door profiles. Lo and behold what looks exactly correct is available from Scotland: www.sealitscotland.co.uk/general_profile.php Reference Arrow Head JME-322-C. Crude measurements also tally. Might be useful for someone in the future As well as splitting the seal had slightly perished in the moulding, so when pulling out left some bits which are hard to remove - the moulding is quite thin, so take care. The seal seems to simply push back into place - no glue. Any idea where you can get a replacement now? I can't seem to find this gasket... My 42DS fridge's gasket is completely blown-out... and the fridge has separated from the counter-top. Rick
Post by fakinx on Oct 6, 2021 17:40:16 GMT
You can order a replacement from any Jeanneau dealer. I got mine from one in Slovenia. I think it was 20€ or so + shippment in 2019.
maya
Jeanneau Model: sun Odyssey 36i
Yacht Name: Maya
Home Port: Nidri
Country: Greece
Post by maya on Oct 30, 2023 12:29:20 GMT
i'm looking at replacing mine but the dimensions i brought back with me are incorrect.
Jeanneau quoted this morning £59.50 + VAT plus Shipping £15.00 + VAT but i want to confirm size.
Could you please supply the length and width of the seal.
Many Thanks
