Post by peters on Jan 20, 2006 18:03:56 GMT
I have a 1997 36.2 The cutless bearing in the shaft strut is getting tired. This bearing is not of the style that I have used. The ones I usually see have a bronze outer case and a hard rubber liner. This bearing seem to be just a rather soft rubber sleeve pressed into the strut. I have found bearing in a Volvo Penta Catalog titled "stern bearing for plastic bonding". Has anyone used this product? If so how does it get installed?
Thank for the help Mark Peters
Post by billyboy on Jan 24, 2006 9:55:00 GMT
I have a SO29.2 and had to replace the cutlass bearing after 400 hours of engine use. I simply ordered a replacement part from the Jeanneau dealer, Westaways in Plymouth. Fitting of this new part was simple and straight forward as soon as the prop was removed. There is a small nylon grub screw to hold the bearing in place.
Post by peters on Jan 27, 2006 17:04:58 GMT
Billyboy
Thanks for the info. I never saw a bearing like these.
Mark
