Post by billhercus on Oct 22, 2005 11:25:50 GMT
Boat is an 83 Symphonie and I need to remove the cabin ceiling lining to upgrade deck fittings.
Most is easily removed by unscrewing but the lining around the cabin entrance is attached to an aluminium extrusion and I'm not sure how to proceed.
Anyone tackled this and can advise?
Post by MartyB on Oct 24, 2005 0:01:24 GMT
I removed the rivots, then pulled it apart, or very gently remove witout removing the rivots. I have not reriveted the alum back. As I still have more parts to replace. ALong with the side glued on liner, in which case the roof liner needs to be removed again! Damned if I do, damned if I don't. SO will fix when ALL the parts are fixed.
