maurice48
VENTURE, a Merry Fisher 805, 2007 model built late 2006.
Post by maurice48 on Oct 30, 2015 11:58:03 GMT
Hi, does anyone know what anodes are required for an MF805 with a Nanni 4.390 engine and bronze propeller?
Post by william51 on Nov 4, 2015 5:50:42 GMT
Just done mine few weeks ago after purchasing the boat. The prop is a 35mm beneteau secured by Allen key bolt. Other anode worth checking is the hull which is located on transon below swim platform, again easy replaced by universal disc type anode. Hope this helps, till getting into the workings of the boat after moving up from a Arvor 190!
Post by billyjnr on Dec 26, 2015 17:49:42 GMT
Dont forget the anode on the swan neck of the exhaust.
thecodfather
Jeanneau Model: Mf 805
Home Port: Hartlepool
Country: Uk
Post by thecodfather on Nov 21, 2021 9:04:34 GMT
Hello, I’m new to using forums and also new to merry fisher boats, but not new to boats.
I’ve just bought a 2004 mf 805 with the tamd41 inboard, it is moored in the finest salt water of the North Sea. I would like to replace the anodes but I don’t know what the diameter of the prop shaft or if it needs an anode on it? Is the propeller anode sufficient? I’d rather go over kill than under kill and regret it down the line if anyone does know I would be very grateful if they would share it with me. Just trying to save the extra cost of lifting the boat to just measure the prop shaft etc. also, there is currently no anode on the stainless steel rudder, would it be advisable to have an anode on it? I would be thankful for any advice.
