Automatic low voltage disconnect for house batteries
Nov 28, 2014 22:08:11 GMT
Post by dbostrom on Nov 28, 2014 22:08:11 GMT
It's clear to me already that JONF is a great place to think aloud and benefit from other people seeing gaps in reasoning, etc. Please bear with me as I do a little thinking aloud here regarding battery management and charter operations. As well, somebody might go down the same path so why not share?
We're purchasing a boat that is an established and successful fleet member of a very excellent charter outfit, ours to use as much or as little as we want subject to our own tolerance for lower revenue, and ours to maintain in face of the various challenges thrown at it by customers (customers being required to have certification of training in cruising operations and a local practicum test).
The 39i we're adopting has a nice almost-fresh set of 3 group 31 NorthStar AGM batteries, one of many sweet features of our choice of boat.
Up until this point I've been exclusively a charter customer when it comes to operating a cruising boat. Most of us here are probably familiar with common quirks of charter boats, in particular knackered batteries. A frequent complaint I've heard from charter owner-operators is failure of customers to understand battery management and the dire impact on operations and economics of running batteries beyond their design discharge level. There's a bit of a vicious circle here; owners become demoralized by dealing with the aftermath of the 1 out of 10 customers who can't manage batteries while the other 9 of 10 competent customers are stuck trying to use abused and shaky batteries in the normal way, hastening the electrochemical death spiral.
I think of the happy batteries in our boat and then cringe when I imagine them facing reality.
It's puzzled me that none of the charters I've been on have included a low voltage disconnect (LVD) for house batteries. Having been in the business of operating remote telecomms sites running on solar power, to me a battery system without an LVD is just as incomplete as a battery system without fuses or circuit breakers. The expense of excessive discharge is brutal, while the expense of adding an LVD is trivial. Modern LVDs manage themselves, with hysteresis, instantaneous load dead bands and all the rest accounted for.
Battery LVD needs to account for its context:
Clearly in the case of a boat facing possible emergency situations and mandatory minimum function we don't want to shed all loads when batteries go slack. At minimum, VHF and GPS input to DSC should be available until batteries simply are not delivering minimum voltage for these devices. Similarly for navigation lights, bilge pumps. What else?
LVD should not be sensitive to transient loads leading to false trip.
LVD should allow an override function that is easily available, easily understood by operators not intimately acquainted with the vessel.
LVD should not be prone to failure or an inherent reliability problem itself. Means for bypass beyond built-in function would be good.
LVD should be programmable for disconnect voltage, offering a range of tolerance for discharge.
This Blue Sea Systems device seems to tick most boxes, assuming it's inserted into the electrical system at the correct juncture:
assets.bluesea.com/files/resources/instructions/980016770.pdf
Unlike many LVD devices the Blue Seas unit utilizes a contactor instead of semiconductor MOSFETs, meaning there's essentially no voltage drop across it.
At ~820W sustaind capacity and ~1,500W for 5 minutes peak load the Blue Seas device is adequate for powering domestic systems on a typical mid-size cruiser, with the conspicuous exception of handling large inverters*. At less than ~$100 US, it's not hard to imagine deploying more than one of these in a boat.
A 200A LVD would handle a substantial inverter along with other loads. Victron makes a suitable device, the BP-200-i:
www.victronenergy.com/upload/documents/Manual-Battery-Protect-EN-NL-DE-FR.pdf
The Victron device is ~$175 US. As it uses MOSFETs for conduction it may not be quite as robust to lightning and will necessarily impose a small voltage drop. It's also not clear from the documentation whether it has an override function.
Has anybody else on board here installed an LVD for their vessel? If so, what model/type and what's your experience with it?
*Better inverters won't attempt to operate when battery voltage is low.
