Post by aridgwell on Mar 9, 2013 8:14:46 GMT
I am looking for a Cutlass Bearing removal tool to extract the bearing whilst the shaft remains in place. I will be delighted to hear from anyone who knows an engineer (Southeast England) that is able to do this work or know where I can hire a unit.
Post by MalcolmP on Mar 9, 2013 9:39:13 GMT
Post by aridgwell on Mar 9, 2013 13:18:17 GMT
Many thanks for your suggestion. I will keep you updated. Rds Alan
Post by aridgwell on Apr 11, 2013 17:42:57 GMT
Hi, once again thanks for your advise. I found an engineer with a cutlass bearing removal tool but it proofed to be ineffective. I discovered that Jeanneau fit a composite bearing, not a brass bearing which is a little more expensive - £20. Therefore when we fitted the removal tool and applied pressure, the edges of the composite bearing started to break down and therefore could not be pushed out. This resulted in the shaft being discounted from the gear box and removed, the old bearing being cut out of the P bracket and the new bearing fitted. Changed a two hour job to fours hours for each shaft.
Rds Alan
