Post by MalcolmP on Feb 4, 2013 16:25:45 GMT
For those who may not be familiar with how forums work the following image may help to show the steps needed; these can be summarised as: Register to set up your username and password Log in - remember that you must use the USERNAME that you first registered the account with, NOT your email address and that your USERNAME may also be different to your Forum name Ensure you are logged in in order to be able to make a post. The very top banner should show if you are "Guest" or "your login name" Once you are logged in click on the most appropriate board for your post to appear - for example for a general one: Then on the far right hand side you will see a tab marked " CREATE THREAD" If you click that you can make your first post Its easy do try...
