Post by sandyrobertson on Jan 31, 2007 20:47:48 GMT
The front window on my Sundream 28 is crazed and needs replacing. Has anyone attempted this? If so I could use some advice.
The replacement part from Jeanneau is flat and, as owners know, the window is slightly curved. As it is 10mm thick would it be possible to draw it down at each end by using long bolts, or, should I try and pre-curve it?
Thanks Sandy
