Post by ralflarra on Oct 21, 2006 14:09:14 GMT
I recently bought a SO 34.2 and my predecessor did not know to install properly the VHF and FM-Radio into the navigation panel. Has anyone an idea how to mount this equipment? Would be very grateful for a reply.
Post by franky on Oct 29, 2006 10:00:57 GMT
I also have a SO34.2.The VHF and Cartype radio are mounted to the right of the nav table below the bookshelf.Ther is plenty of space available in this are if toy unscre the panels inside the bookshelf. I have upgraded the VHF (RAY 240e) and now have the main unit mounted under the nav table and the control mike at the companionway. If you get in touch I can give tou more info.
Post by ralflarra on Nov 15, 2006 14:59:49 GMT
:)Thank you, I will certainly check this possibility.
Ralf
Post by franky on Nov 19, 2006 11:34:09 GMT
just got back from winterising the boat and took a photo of the radio/cd and VHF installation.If you want a copy let me know
Post by ralflarra on Apr 14, 2007 8:42:43 GMT
;DOh yes please do so, this will give me and eventually the local Jeanneau dealer, who is more or less helpless, an idea, what to do.
Thank you very much
Ralf
Deleted
Deleted Member
Post by Deleted on Apr 16, 2007 9:37:40 GMT
on other note we have a car type radio & CD system the original owner used a car arial placed in a locker which does not work. Is there any type of system or spliter I could use or fit that would let this share the marine VHF arial !!!!!!!!
I have been told there is a system but can find no info on it local chandlery does not know what
Deleted
Deleted Member
Post by Deleted on Apr 16, 2007 9:38:35 GMT
I have been told there is a system but can find no info on it local chandlery does not know what I am after.
Post by ralflarra on Apr 17, 2007 8:13:59 GMT
:DHi Paul342 The following info should solve the problem. I found this device, which works as an active switch between VHF and radio at Niemeyer Yacht supplies in Germany (http://en.awn-shop.de/shop/produktdetails/0410104).
GLOMEX is an Italian manufacturer, but I did not find any info on this switch on their site.
GLOMEX Antennenweiche RA 201
Aktive AM/FM Radioweiche zum Anschluss einer UKW-Funkanlage und einem Radio an eine UKW-Antenne. Mit Anschlusskabel 12V DC.
Name GLOMEX Antennenweiche RA 201 Number 410104 Price per Unit €54,99 Availability sofort
Good luck Ralf
