Post by napoleon on Dec 4, 2010 15:52:34 GMT
Anyone know how the microwave oven which is fitted as standard in this model is fastened in? I wish to remove it for some electrical reworking but cannot see how it is secured. It is solidly fixed but no bolts appear underneath and there is no access at the sides or top.
Post by napoleon on Mar 14, 2011 11:24:38 GMT
Found the solution for anybody who may have the same problem. The microwave is screwed from underneath to a separate wooden base which itself is secured by hidden screws. Thses are best located with a mirror from inside the lower cabinet. Once found the job is easy.
Post by MalcolmP on Mar 14, 2011 18:16:43 GMT
Found the solution for anybody who may have the same problem. The microwave is screwed from underneath to a separate wooden base which itself is secured by hidden screws. Thses are best located with a mirror from inside the lower cabinet. Once found the job is easy. Thanks Napoleon May well be similar on the Sun Odysseys fitted with microwaves - I had looked at ours but could not see any fixings at all Malcolm
Post by ripster1 on Mar 27, 2011 20:33:19 GMT
Found the solution for anybody who may have the same problem. The microwave is screwed from underneath to a separate wooden base which itself is secured by hidden screws. Thses are best located with a mirror from inside the lower cabinet. Once found the job is easy. Thanks for that info. We have the P32 and I have often wondered how the MW comes out from its slot!
