New 2007 Sail and Power Models
Jul 13, 2006 21:55:24 GMT
Post by MalcolmP on Jul 13, 2006 21:55:24 GMT
Dear all
The following info is from factory press releases issued today 13/07/06 on some of the new Sail & Power Models for 2007
I will be hoping to have some advanced pictures & specs for the August edition for publication on www.jeanneau-owners.com
Fair winds
Malcolm
Jeanneau Owners Network
Jeanneau is active and highly competitive in the international market, with ranges of timeless yachts that are easy to live with, and are built in the true maritime tradition.
Jeanneau introduces an entry-level range of 20' yachts for short coastal cruises: the Sun range; The Sun Odyssey range of 29' to 49' yachts for blue water cruising; The Sun Odyssey Deck Saloon 39' to 54' range styled by Garroni; The Sun Fast range of cruiser-racers.
The new Jeanneau models for 2007 to be shown at the autumn 2006 European boatshows are: The Sun Odyssey 36i; The Sun Odyssey 39i Performance; The Sun Odyssey 39 DS: The Sun Odyssey 42i
Sun Odyssey 36i
The Sun Odyssey 36i is the new high-performance cruising yacht built for comfort and designed for those looking for a relaxed way of getting away from it all Its cutting-edge Sun Odyssey family design give it the personality of a real blue-water boat, whilst its technical fittings are unequalled, and include top brands such as Harken for properly-sized deck fittings and Selden for top-class spars.
Two below-deck layouts are offered, both using very high quality materials.
Overall length 10,94 m /35' 10"
Max beam 3,59 m / 11' 9''
Displacement 5700 Kg / 12 566 lbs
Berth 5 / 7 / 9
Cabin 2/3
Engine Yanmar 29 HP / 21 kW
CE category (in process) A-8 / B-10 / C-12
Architecte / Designer Marc Lombard / Jeanneau Design
Sun Odyssey 42i
The ultra- comfortable new Sun Odyssey 42i is designed in the true maritime tradition. With intelligent design from the Jeanneau Design Department in cooperation with designer Marc Lombard, this new yacht offers spacious, functional below-deck accommodation with 2 cabins/2 head compartments or 3 cabins/ 2 head compartments.
Technical equipment is fully integrated to release the maximum possible space for on-board comfort.
The lines of the new Sun Odyssey 42 are modern and flowing.
Generous sail plan
Principal provisional specifications
Overall length 12,85 m /42' 2"
Max beam 4,13 m / 13' 6''
Displacement 8000 Kg / 17 637 lbs
Berth 4 / 6 + 3
Cabin 2/3
Engine Yanmar 55 HP / 40 kW
CE category (in process) A-9 / B-10 / C-12
Sun Odyssey 39DS
The many features and benefits of the Sun Odyssey 39 DS, include:
Hull design by Marc Lombard, the internationally renown naval architect, ensures seaworthiness, sleek lines and performance; The high level of interior comfort and styling is due to the vast experience and savoir-faire of the Italian design office of Vittorio Garroni.
The key element of the interior layout is the spacious liveability of the boat. 2 large cabins can accommodate 5 to 7 people.
Add to this a real head compartment with a shower, a comfortable and inviting saloon bathed in light from the sleek windows and your time spent onboard the Sun Odyssey 39DS becomes a true pleasure.
A large cockpit with twin helms and a generous cockpit table, every element has been conceived with sailing comfort in mind (70m² of sail area).
Overall length 11, 86 m / 38'10"
Max beam.3, 88 m /12' 8''
Displacement 7262 Kg / 16 010 lbs
Engine Yanmar 40 HP / 29 kW
CE category (in process).A - 8 pers
Architecte / Designer Marc Lombard / Garroni Design / Jeanneau Design
Prestige 30
The new Prestige 30, in keeping with the Prestige tradition, offers many features for the most discriminating owners:
The world-renown Italian design office of Vittorio Garroni leant the elegant and modern lines to the Prestige 30; The stable and powerful hull provides for comfortable cruising. Designed by the architects at Jeanneau Design whose savoir-faire and experience is clearly felt when at the helm; The interior is luxuriously appointed with a large owner's cabin, a spacious saloon and a true head compartment.
Available in an open or sportop version, the Prestige 30's comfortable cockpit would be considered spacious on a 34-footer.
Single or twin engines are available in diesel or petrol.
New Powerboat exhibited in Cannes and Southampton boatshows 2006
Overall length 9,10 m / 29' 10"
Max beam 3,30 m / 10' 9''
Displacement 300 Kg / 9480 lbs
Engine 380 HP / 293 kW - 560 HP / 418 kW
Cabin 1
Berth 4
Fuel capacity 500 l / 132 US gal
CE Category (en cours / in process) B - 8 pers
Architecte / Designer Garroni Design / Jeanneau Design
The Prestige 30, the first open power yacht in the Prestige range of luxury cruising power yachts, will be on boatshows at Cannes and Southampton 2006
Prestige 50 S
Jeanneau Design and Garroni Design have worked in close collaboration to create this, the largest boat in the Prestige range, which combines generous space and extreme elegance, comfort and luxury with high performance and excellent sea-keeping qualities.
Developed using Jeanneau's very latest high-technology expertise, the Prestige 50 is exceptional at every level. Her appearance at the winter boat shows and the tests conducted with the European press confirm the Jeanneau reputation for building large motor yachts.
Jeanneau is the first French boat builder to fit the latest Volvo D9 575hp engines. In France, these new-generation engines are fitted with prop shafts and underwater exhausts, resulting in considerably lower noise levels and eliminating all fumes.
Principal specifications
Overall length 15,36 m /50'
Max beam 4,36 m / 14' 3''
Displacement 13 000 Kg / 28600 lbs
Cabin. 2 ou 3
Berth 4 ou 6
Fuel capacity1 650 l / 436 US gal
CE Category B -12 / C-14
The Prestige 50, the flagship of the Prestige range and our major new launch of 2006, has already appeared at the Düsseldorf and Barcelona boatshows, and will also feature at Cannes and Southampton 2006.
Merry Fisher 585
Handsome, strong and seaworthy, the new Merry Fisher 585 is distinctive for its modern Jeanneau lines.
Designed for coastal cruising and fishing, this new 5.75-metre version is easy to helm and behaves impeccably at sea. Fitted with a 100 hp outboard, the cockpit is uncluttered and well-designed to make maximum use of space with highly practical fittings and storage solutions: another faultless design from Jeanneau.
New powerboat to be exhibited at the Grand Pavois Boatshow 2006
Overall length.5,75 m / 18'10"
Max beam 2,40 m / 7'10''
Displacement 850 Kg / 1874 lbs
Cabin 1
Berth 2
Fuel capacity 100 l / 26 US gal
CE Category (en cours / in process) .C-6
The Merry Fisher 585, the latest addition to the Merry Fisher range of 5 to 9. 25 metre fishing and cruising boats, will be unveiled at the Grand Pavois 2006 boatshow in La Rochelle
Cap Camarat 635
The Cap Camarat 635 fits into the middle of a range that's now celebrating its 20th birthday, thanks to its strength, reliability, performance and value.
The new Cap Camarat 635 has been designed by Italian stylists Garroni, working closely with the Jeanneau design department. The real skill of the designers can be seen in the detailing, and especially in the cockpit layout either side of the central console.
The impression is one of space wherever you look. The driving and passenger positions inspire confidence and deliver high comfort levels at sea High quality fittings throughout.
Overall length 6,15 m / 20'2"
Max beam2,44 m / 8'0''
Displacement 900 Kg / 1984 lbs
Engine 200 HP / 147 Kw
Fuel capacity 136 l / 36 US gal
CE Category (en cours / in process) C-7
The Cap Camarat 635 slots into the middle of the Cap Camarat range of 5 to 7-metre outboard-powered multiprogramme boats. This new model will be unveiled at the Grand Pavois 2006 boatshow in La Rochelle
Fair winds
Malcolm
Sun Odyssey 36i
Berth 5 / 7 / 9
Cabin 2/3
Sun Odyssey 42i
Generous sail plan
Berth 4 / 6 + 3
Cabin 2/3
Sun Odyssey 39DS
Prestige 30
Cabin 1
Berth 4
Prestige 50 S
Cabin. 2 ou 3
Berth 4 ou 6
Merry Fisher 585
Cabin 1
Berth 2
Cap Camarat 635
