geary
Post by geary on Jan 24, 2023 23:09:15 GMT
When plugged into shore power I have no power to the AC outlets and their is no voltage showing on the power/control board AC meter. I do have power to the battery charger and hot water heater. Reverse polarity light flickering (has been doing this for years) This suddenly happened. Anybody have any Ideas as to where I go to search for the solution. Are there any hidden circuit breakers that would control this) (2009 Jeanneau 42')
Post by Zanshin on Jan 25, 2023 1:04:25 GMT
Post by rxc on Jan 25, 2023 15:06:37 GMT
You should also check the GFCI trips on the outlets that have them. Not all the outlets have GFCI protection, but some are ganged together. Boats are a wet location, and the GFCI trips are sensitive to the moisture in this environment.
