barryl
Yacht Name: Sound’s Great
Home Port: Mt. Sinai, NY
Post by barryl on Jan 20, 2023 19:06:42 GMT
Hello, The forward hatch on my 2011 Sun Odyssey 409 has a crack in it. This is the hatch in the V Berth. The crack isn't bad (yet) but I don't want to take a large breaking wave on the bow and have the hatch shatter. Any ideas on sourcing a replacement? The hatch is frameless and has a curve. So it will be complicated (and expensive). Thanks, Barry
Post by Don Reaves on Jan 20, 2023 21:09:16 GMT
Would it be possible to replace just the glazing (the clear part)? I had the glazing in one hatch start leaking, and it was straightforward to remove it, clean up the caulk and reinstall it. If you could get a replacement cut from the proper material, it might be easier than finding a drop-in replacement.
Post by Tafika II on Jan 20, 2023 21:13:49 GMT
A friend of ours (not at all mechanically inclined) used HatchMasters. Not cheap but good quality work. link
Post by puravida35 on Jan 22, 2023 23:47:47 GMT
I believe that is the same hatch as on my SO439. It is made by Lewmar. My hatch has “Lewmar” etched on the inside near forward edge. Also shows “30193201 12C15”. Not sure if that’s a part number?
barryl
Post by barryl on Apr 30, 2023 3:08:10 GMT
Hello,
I was able to order the hatch from the local Jeanneau dealer. It was expensive ($700) but was a direct replacement and relatively easy to install.
Barry
