Post by timc on Jan 4, 2023 23:42:05 GMT
Hi all, I have a 2017 NC33 which came with around 27m of 10mm anchor chain. I want to increase my chain length to around 50m to give more options when anchoring. Does anyone know of a weight limit for the chain locker on the NC33 please? Thanks.
Post by Charlie-Bravo on Jan 5, 2023 9:25:35 GMT
I did this, all be it on a SO 35, I went with 50 meters of 8mm chain as it is about the same weight as 27M of 10mm, it’s more than strong enough. The only issue I had was finding a 8mm gypsy wheel for my windlass, an added expense offset by the smaller chain being cheaper, worth finding one first if you head down this route.
A cheaper option is to use your chain and a long rope rode (if your windlass copes with rope), some say rope is better as it is a nice big soft ‘spring’ for secure anchoring and easy to handle , I like chain, it helps me sleep.
I don’t know of weight limits for anchor lockers , but weight distribution will effect the boat behaviour to some degree, will it be noticeable? only another NC33 owner will be able to tell you, hope an owner with the experience comes along for you.
CB (10mm Gypsy for Quick windlass available here.)
