Post by sbarouch on Dec 27, 2022 1:06:58 GMT
Does anybody know the shaft size on the Sun Odyssey 440? I need to buy replacement anodes for the shaft and I don’t know the shaft size.
Post by shenandoah on Jan 3, 2023 18:15:53 GMT
Sbarouch, Our SO 440 uses a 30 mm anode on the shaft. Hope that helps.
Warm regards, Chuck
Post by sbarouch on Jan 7, 2023 1:40:05 GMT
Thanks Chuck. Would you know the size for the prop nut?
Post by shenandoah on Jan 13, 2023 18:09:51 GMT
Sorry, been sailing and just now seeing this.
We have the flexofold folding prop, if you have the same prop then the cone shaped anode would also be 30mm.
Post by shenandoah on Jan 13, 2023 18:30:17 GMT
I just looked it up to verify and there is only one size for Flexofold props, so if you have that prop it should be simple to order.
