Post by davidtav on Sept 30, 2022 14:30:36 GMT
I have a Sun Odyssey 32.2 … the indicator light for shorepower on the switch panel has stopped working … the shore power is still working though. Do I just need to wire in an ordinary led? Or is there anything special about this? Appreciate any advice. Thanks
Post by sitara on Sept 30, 2022 22:36:50 GMT
You are working with high voltage which can be deadly. I would suggest having a qualified electrician do this.
Post by Zanshin on Oct 1, 2022 9:33:42 GMT
The indicator light is not on the high-power AC current. Can you access it without going close to any high-power AC lines? If you have a voltmeter you can see what DC voltage it runs at and then purchase a replacement at any electronics store or on-line.
Post by davidtav on Oct 4, 2022 19:00:56 GMT
Well on further investigation this indicator light is on the AC circuit. It looks like a neon bulb which has broken up.
Post by Zanshin on Oct 5, 2022 6:45:55 GMT
Do you have a multimeter to check that with? Is the panel a Scheiber?
Post by MartyB on Oct 6, 2022 5:07:45 GMT
Not sure if "Blue Seas" products are available in your part of the world. They have a few colors of small led bulbs for AC and DC panels. Not sure if they will fit in your brand of panal....
Post by davidtav on Oct 6, 2022 10:36:20 GMT
Not sure if "Blue Seas" products are available in your part of the world. They have a few colors of small led bulbs for AC and DC panels. Not sure if they will fit in your brand of panal.... Marty Thanks for this. Yes it is a Scheiber panel. It was definitely a neon bulb originally. But I have found a Blue Seas Led item which should be a straightforward replacement. So thanks for that pointer.
