ajv
Jeanneau Model: Sun Odyssey 410
Yacht Name: Alchemia
Home Port: Ionian
Country: Greece
Post by ajv on Sept 27, 2022 9:56:10 GMT
We have a 410 launched in June this year, under sail or power we can hear a creaking sound from the aft of the side deck.
question Is this common or a fault with our yacht? this is the first time I have ever come across this sound after sailing many yachts. This is more pronounced on the starboard side.
maybe its common with this type of walk around deck!
I have asked our yacht broker and still waiting for an answer after many weeks!
Post by MickeyB on Sept 27, 2022 12:55:36 GMT
Hi. Is the sound nearer to the stays? Does it only happen when rolling, or pounding into waves etc?
If you can make it happen (by rocking the boat for example), record a quick video and hopefully we can hear the sound and help out more.
Mike
Post by shenandoah on Sept 27, 2022 15:20:53 GMT
ajv, We have a 440 not the 410 but it is a wrap around deck. We do not experienced any creaking sound like you are describing.
Do you here it while topside or when you are down below?
Warm regards,
Chuck
Post by npmr on Sept 28, 2022 17:24:11 GMT
We had a similar problem on our S.O. 33i.
The dealer's expert took the under-deck lining down and applied more sealant/insulation to the area.
It cured the problem.
It may be worth a look?
adventure
Yacht Name: Adventure
Home Port: Coconut Grove, FL
Post by adventure on Sept 29, 2022 17:53:44 GMT
We have the same issue with our 410 delivered in June also. Our creaking sound is coming from the deck above our port aft cabin. Our dealer said the issue is where the cabin locker pushes up against the walk around deck. He forcefully pushed/banged the top left side of the locker up against the deck and the creaking stopped! The dealer said that if it started again they might need to glue it in place. And now it has started creaking again so I need to contact him.
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Sept 29, 2022 18:11:48 GMT
Hi. Is the sound nearer to the stays? Does it only happen when rolling, or pounding into waves etc? If you can make it happen (by rocking the boat for example), record a quick video and hopefully we can hear the sound and help out more. Mike Hi and thanks for the suggestion I will make a recording. This sound only occurs when we are sailing or motoring, I can’t make by rocking the yacht.
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Sept 29, 2022 18:14:33 GMT
We have the same issue with our 410 delivered in June also. Our creaking sound is coming from the deck above our port aft cabin. Our dealer said the issue is where the cabin locker pushes up against the walk around deck. He forcefully pushed/banged the top left side of the locker up against the deck and the creaking stopped! The dealer said that if it started again they might need to glue it in place. And now it has started creaking again so I need to contact him. This is exactly the same problem although mainly from the starboard aft walk around area. I will have to try my dealer although I already have issues outstanding with my dealer and lack of response!
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Sept 29, 2022 18:15:55 GMT
We had a similar problem on our S.O. 33i. The dealer's expert took the under-deck lining down and applied more sealant/insulation to the area. It cured the problem. It may be worth a look? I will ask our dealer to look into the problem area, it’s not what we expected to hear from a new yacht.
ajv
Home Port: Ionian
Country: Greece
Post by ajv on Sept 29, 2022 18:17:01 GMT
ajv, We have a 440 not the 410 but it is a wrap around deck. We do not experienced any creaking sound like you are describing. Do you here it while topside or when you are down below? Warm regards, Chuck The sound is very noticeable from the topside while motoring and sailing.
Post by shenandoah on Sept 29, 2022 19:01:20 GMT
Curious. I would think it is either the deck to hull seam or the joinery. If the latter then I would assume it would be louder inside. You are probably going to have to track it down while underway then hopefully your dealer will make it right.
Good luck trouble shooting.
Post by awfreo on Oct 27, 2022 5:10:29 GMT
My SO 410 had the same creak....no problem for the dealer....in construction, deck is lowered onto the furniture modules and packed with sealer etc...if you don't have a forward head all unfilled grooves etc obvious in the ceiling.... if part of the furniture touches the deck mould or too thin on filler, under pressure... will get a creak when the deck moves.
My dealer via shipwrights slightly trimmed timber (stbd cabin cabinet side) and repacked with extra sika.....problem solved.
My job done under warranty.....
cheers
AWFREO
