DavidR
Jeanneau Model: Sun Odyssey 42i
Yacht Name: Sparkles
Home Port: Whangamata
Country: New Zealand
Post by DavidR on Sept 9, 2022 23:17:30 GMT
Hi everyone, wondering if anyone can put me straight on the wiring for the ventilation blower on a 2007 Sun Odyssey 42i. I'm guessing it will be similar to many of the other SOs this age. I've recently replaced the failed blower but there is no power in the line running to it. Is this on the ignition circuit? And is it normally on all the time the engine is running? I have read that some models have a thermostat control but can't see one.
Any help appreciated.
plas50
Jeanneau Model: 42 DS
Yacht Name: Decibelle
Home Port: Sant Carles de la rapita
Country: Spain
Post by plas50 on Sept 10, 2022 6:33:39 GMT
I recently replaced mine. Mine was on the ingnition side. And runs when the engine is running. I don't appear to have a thermostat on the 42DS. It gets quite warm in the engine compartment, especially in Spain, and the fan runs constant during engine running.
Andy
Post by Trevor on Sept 10, 2022 8:33:43 GMT
Hello Davidr,
The SO42i will most likely have the same wiring as the SO42DS as they have the same hull. The fan is fed with a small relay located in the wiring behind the alternator. The relay is switched when the ignition is on. It is the same relay that enables the anchor winch to operate only when the engine is running. The relay is fed by a 7.5amp fuse located in a fuse holder just inboard of the battery switches under the aft cabin mattress. If the anchor winch works when the engine is running, it is not the relay at fault as it does both jobs.
I hopes this helps.
Post by NZL50505 on Sept 11, 2022 21:45:41 GMT
I’m not a fan of the thermostat option.
Even if the engine isn’t hot enough to need a fan running, the blower still gives 2 other key benefits (1) improves oxygen flow to the engine (2) minimises engine room smells from the saloon. If you are used to a continuous blower and then try running your engine without it, you’ll soon notice an ‘engine smell’ the saloon.
Andrei
Jeanneau Model: SO 409
Yacht Name: Leto
Home Port: San Diego, CA
Post by Andrei on Sept 12, 2022 19:44:07 GMT
I agree it is not good to run the engine without the blower, thermostat or otherwise. An even better option for this blower, which I've seen on a newish boat by Hanse, is wiring with off timer - the blower runs for additional 60(?) seconds after the ignition is turned off to safeguard against residual heat build up once the engine cooling water flow shuts off.
Andrei
Yacht Name: Leto
Post by Andrei on Sept 12, 2022 20:00:08 GMT
Also, I've got wiring for 2013 SO 409, it might be close enough to be useful. Looks like the relay is triggered by the alternator output, not the ignition switch, which makes sense to me.
Post by Trevor on Sept 12, 2022 21:50:44 GMT
The schematics are available on this website by going to specifications/manuals and finding the SO42DS schematics. The SO42DS is the same hull as the SO42i and the wiring of the hull is the same.
OhWell
Jeanneau Model: 43DS
Home Port: Ft. Lauderdale
Post by OhWell on Sept 14, 2022 12:06:35 GMT
Thank you for this thread.
I've replaced the relay and the checked the 7.5 amp fuse on our 2001 43DS. Still no power to the blower with the engine running. Any other thoughts?
Thanks
Post by zaphod on Sept 14, 2022 14:28:46 GMT
Thank you for this thread. I've replaced the relay and the checked the 7.5 amp fuse on our 2001 43DS. Still no power to the blower with the engine running. Any other thoughts? Thanks Are you getting power to the relay? Is the relay closing when the engine switch is on? Time to break out the multimeter and start troubleshooting.
OhWell
Post by OhWell on Sept 16, 2022 20:29:50 GMT
Mystery solved. On our 2001 there's a thermal switch in the negative wiring inside the blower hose so it will not come on until the engine space gets to around 100F. You won't see voltage at the blower until the space heats up or you jump over the switch. With reliance on big alternators these days it probably makes sense to just let it run all the time.
Post by zaphod on Sept 16, 2022 21:39:52 GMT
Mystery solved. On our 2001 there's a thermal switch in the negative wiring inside the blower hose so it will not come on until the engine space gets to around 100F. You won't see voltage at the blower until the space heats up or you jump over the switch. With reliance on big alternators these days it probably makes sense to just let it run all the time. Ah that explains it! I would think itcwould make sense to have it run continuously to keep the engine compartment in negative pressure. Are you in a cold climate? Maybe the fan is wired that way to help the engine warm up faster or for cold starting?
DavidR
Post by DavidR on Sept 29, 2022 22:17:48 GMT
Hi everyone, wondering if anyone can put me straight on the wiring for the ventilation blower on a 2007 Sun Odyssey 42i. I'm guessing it will be similar to many of the other SOs this age. I've recently replaced the failed blower but there is no power in the line running to it. Is this on the ignition circuit? And is it normally on all the time the engine is running? I have read that some models have a thermostat control but can't see one. Any help appreciated. Thanks for the great advice everyone. Problem sort now. As suggested no thermostat and problem was a short. Looking forward to a saloon without the fumes!
