Water under bed.
Sept 4, 2022 15:17:11 GMT
Post by nickwight on Sept 4, 2022 15:17:11 GMT
I was down at the boat (2016 NC9) this morning doing some bits & pieces of maintenance and a found water (salt) in the compartment just aft of the bow thruster tunnel, under the forward berth bed. Using a hand pump I removed around 20-25 litres of water! I plan to investigate this further tomorrow, but before a I pull the boat to pieces, I wonder of anyone has any relevant information regarding:
1/. How salt water would get into that small compartment? No obvious sign of leakage through the thruster tunnel.
2/. This is the first time that I've really looked at the hull construction since we bought the boat back in May and I am a little confused as it differs from all other boats that we've had. Their appears to be a gel coat finished liner that sits on top of the raw fiberglass inner of the hull and this in some places results in a large void between the two. Both bilge pumps appear to sit on this upper tray and I therefore wonder how water is to be pumped out of these voids? In fact I am a bit concerned as it would be possible to ship a significant amount of water before either pump would be triggered!
We've done about 60 hours running this year and some was in moderate conditions with water breaking over the bow and against the side windows, but i had assumed -- wrongly it seems -- that the pumps would take care of any significant water ingress and I have never noticed an accumulation in the engine bay during routine mechanical checks.
Anybody have any thoughts or useful information?
