mhgpe
Jeanneau Model: Sun Odyssey 44i
Yacht Name: SELINIM
Home Port: NYACK, NY
Country: United States
Post by mhgpe on Aug 1, 2022 9:30:49 GMT
I am a brand new owner of a 2009 Sun Odyssey 44i, It looks like I will need to replace b both shower sump pumps in both heads. I can't seem to locate the recommended complete sump pump replacement kits. I would greatly appreciate someone's experience on this. I want to replace both them.
Thank you
jaminb
Post by jaminb on Aug 1, 2022 18:30:46 GMT
Just serviced mine on a 2006 S/O 37 not sure if they will be the same.
barryl
Yacht Name: Sound’s Great
Home Port: Mt. Sinai, NY
Post by barryl on Aug 1, 2022 19:39:11 GMT
Hi,
My 2011 SO 409 has Viking Power 16 pumps for Bilge Water pump Shower pump for both heads
What happens when you activate the shower pump switch? If nothing happens, have you checked the fuse / breaker? Have you checked power to the pump? The pumps are very reliable. You may need to change the diaphragm but it's rare for the pump to not work at all.
Barry
mhgpe
Yacht Name: SELINIM
Post by mhgpe on Aug 2, 2022 10:44:59 GMT
I think I will replace the diaphragms regardless. I can't locate the breaker for the shower pumps, the Jeanneau Manual I downloaded is not detailed.
barryl
Post by barryl on Aug 2, 2022 18:10:36 GMT
Hi,
On my 2011 409 the fuse / breaker for the shower pump is fuse No 4 on the left fuse row, behind the switch panel
Barry
mhgpe
Yacht Name: SELINIM
Post by mhgpe on Aug 4, 2022 22:49:20 GMT
Thank you. I will check.
