Post by sanjuan895 on Jul 28, 2022 17:30:28 GMT
I’ve got oily substance that keeps showing up in the basin forward of the outboards below the steering rod. I think it’s coming from the hydraulics because it seems to reappear when been turning the outboards hard port or starboard.
Wondering if this description lines up with anyone’s knowledge of the fluids back by the outboards and if anyone has seen a similar problem.
Post by garyguise on Jul 29, 2022 15:08:01 GMT
What is the year of your boat and how many hours are on the engines?
Post by sanjuan895 on Jul 29, 2022 23:06:28 GMT
[mention]garyguise [/mention] 2017. I’m just shy of 120h on both engines. Last maintenance was at 100h
Post by garyguise on Jul 30, 2022 13:21:46 GMT
Pretty sure the 2017 was the last year of the previous 895 model. Did that also come with twin Yamaha 200s? Although you're likely past the 5yr engine warranty (that most dealers will give) I'd see if extending it is still possible.
Hoping this issue isn't serious but even if it isn't, that longer warranty might save you in the long run if you plan on keeping the boat for a while.
Post by sanjuan895 on Jul 30, 2022 16:26:30 GMT
Yep. Twin Yamaha 200s. Thanks for the pointer on extending the warranty. I’ll look into it!
Post by sanjuan895 on Aug 1, 2022 18:28:04 GMT
Had some time to take a much closer look at the steering system and I’m fairly confident that I’m bleeding steering fluid from the lines. I’m starting to get some slop in my steering which further confirms I’m getting air in the system.
