piemon
Jeanneau Model: NC11
Yacht Name: ALLON-Z
Home Port: Reedville, VA
Post by piemon on Jul 11, 2022 13:38:06 GMT
Hi, i have a 2017 NC11 and loving it. The side helm door seems to work itself open when cruising with slight chop. Can't seem to find a way to tighten it or how it can be adjusted - any insights? Thanks!
Post by Hanzel on Jan 3, 2023 19:30:02 GMT
Hi Piemon, I had same problem with our NC11, turned out that we did not close the door completely. When you think it is closed, use some more power to press it in the door-rubbers and you feel at the closing handle a real ‘end’ point instead of a soft end point.
piemon
Yacht Name: ALLON-Z
Post by piemon on Jan 9, 2023 13:25:45 GMT
Thank you - I'll give that a try!
