mnbuarque
Jeanneau Model: SO DS 50
Yacht Name: Carmel
Home Port: Paraty
Country: Brazil
Post by mnbuarque on May 15, 2022 1:19:48 GMT
Hi guys! Very stupid question, but without the answer I just can't order any part or start any decent maintenance approach.
Where can I find the infamous HIN and CIN numbers of my recently acquired SO DS 50 2010 ? BR Marcelo
dakota1
Jeanneau Model: 49 DS
Post by dakota1 on May 15, 2022 2:46:50 GMT
Try starboard side of hull, aft and just forward of transom
Post by Don Reaves on May 15, 2022 13:24:56 GMT
The numbers will be fairly high on the starboard side, in all likelihood. Unlike on boats from other manufacturers, the impression in the gelcoat is quite subtle, and may not be visible unless the light is just right. My insurance company wanted a rubbing of the numbers, and that was quite difficult.
The HIN is also located somewhere in the engine compartment, but the actual location seems to vary by model, so I can't tell you where to look.
Post by MartyB on May 15, 2022 21:08:09 GMT
Reality, a hull number is not needed to do typical maintenance, order parts per say. An owners manual is a much better thing to find from a maintenance and to a degree some of the parts and pieces. Since Jeanneau like a lot of boat manufactures use other sources for parts, finding that said manufacture based on a part# on that item is the best way to get an equal part. Then so e of us have 40 yr old versions, with 2-3 ownership transfers of manufacturing plant, even that part numbers on OM are useless. Don't be surprised if you have to do some hunting at different Chandler's marine supply places for parts.
Post by NZL50505 on May 15, 2022 21:27:41 GMT
Hi guys! Very stupid question, but without the answer I just can't order any part or start any decent maintenance approach. Where can I find the infamous HIN and CIN numbers of my recently acquired SO DS 50 2010 ? BR Marcelo I went through this last year on my 2012 50 DS and it was a nightmare to find unless you get the lighting and angle just right. Apparently you can try using a piece of paper and pencil to do a ‘rubbing’ but I didn’t do that. Much easier is to look in your engine room on the starboard side (through the access hatch) and you’ll probably find it stamped in plain sight. That’s what I have.
mnbuarque
Yacht Name: Carmel
Home Port: Paraty
Country: Brazil
Post by mnbuarque on May 20, 2022 0:58:36 GMT
Hi guys! Very stupid question, but without the answer I just can't order any part or start any decent maintenance approach. Where can I find the infamous HIN and CIN numbers of my recently acquired SO DS 50 2010 ? BR Marcelo I went through this last year on my 2012 50 DS and it was a nightmare to find unless you get the lighting and angle just right. Apparently you can try using a piece of paper and pencil to do a ‘rubbing’ but I didn’t do that. Much easier is to look in your engine room on the starboard side (through the access hatch) and you’ll probably find it stamped in plain sight. That’s what I have. Thank you ! I will try your way !!!
mnbuarque
Yacht Name: Carmel
Home Port: Paraty
Country: Brazil
Post by mnbuarque on Jul 6, 2022 22:25:56 GMT
I went through this last year on my 2012 50 DS and it was a nightmare to find unless you get the lighting and angle just right. Apparently you can try using a piece of paper and pencil to do a ‘rubbing’ but I didn’t do that. Much easier is to look in your engine room on the starboard side (through the access hatch) and you’ll probably find it stamped in plain sight. That’s what I have. Thank you ! I will try your way !!! Can you try to indicate in a picture where you have found that? that would enable me to reduce my "searching area " Many thanks in advance! ( could attach a picture to help here....but I just dont know how I do it ! shame on me)
