Post by dave346 on May 6, 2022 16:45:27 GMT
Hi, looking for some advice on the inter shroud mast fixture plates (Seacraft mast) on my 2015 SO41DS. Noticed on my recent venture up that mast, that where the shroud fixture inserts protrude through the mast, just above the plate is a small hole (about 5 mm) that goes through the mast and appears to also go through the fixture plate on the inside. Was expecting there should be a small screw or rivet in that hole, however can’t believe anything that small has any structural importance. That is the case for all the fixture plates on my mast, so don’t think it’s wear and tear that there’s nothing in those holes. Just done a look around the Marina at other Jeanneau’s, there’s and older 42 with blank holes, but a 479 with a slotted lug screw in them. So any advice on what mine should be ?
Thanks
